TECHNICAL QUESTION, HELP REQUIRED PLEASE!
I OWN A 98' GOLF VR6 OBD 2. IF I WAS GOING TO PUT A SCHRICK MANIFOLD ON IT WHICH WAS A OBD 1 FITMENT WOULD I THEN BE ABLE TO RUN A 2.9 THROTTLE BODY? IS THIS POSSIBLE AND IS IT A LOT OF WORK TO DO ( DIFFERENT PIPE WORK, PLUGS OR SENSORS ) ?
ANY HELP IS GRATEFULLY APPRECIATED
THANKS, IAN
If it was a 2.9 OBD2 throttle body yes but they are rare, but if you do that I'd suggest a remap as the 2.9 tb can cause probs on a 2.8 but if you fitted it and had a remap you'd get the most out of it and adjust for the larger tb
