Richard Andrews 0 Posted April 22, 2009 Report Share Posted April 22, 2009 Just in the process of fitting. I have removed the VW box and now have the senser part and the part sticking out of the inside wing. Do I link the filter via these two existing parts? Link to post Share on other sites
Roan 0 Posted April 22, 2009 Report Share Posted April 22, 2009 No just link the intake to the filter with some silicone hose and worm drive clamps. You will find the intake pipe from the wing will be impossible to fit onto the filter at the other end. I think there's a fitting guide in the Premium Member's section Link to post Share on other sites
Richard Andrews 0 Posted April 22, 2009 Author Report Share Posted April 22, 2009 £15, that seems reasonable, will sort that out. What about the other end? Do I bypass the senser tube or link it to that, again useing some silicone hose cause that tubing that comes with it does not fit over the engine end of the filter. Link to post Share on other sites
SankysVR6 1 Posted April 22, 2009 Report Share Posted April 22, 2009 You will need a bit of silcone hose, to connect the BMC to the MAF.AKA sensor to you. :-* Link to post Share on other sites
