Antihero1981 8 Posted May 6, 2009 Report Share Posted May 6, 2009 i have put most the pipework and wires in , just need some info on the following1.best place o put t-junction on vacum line2.best place to install negative + ignition wirewant to finish it off tomorrow , so any help would be goodthanks Link to post Share on other sites
jims13 6 Posted May 6, 2009 Report Share Posted May 6, 2009 off the radio for the wires.. and brake booster for the vacum Link to post Share on other sites
Antihero1981 8 Posted May 6, 2009 Author Report Share Posted May 6, 2009 i was thinking about the radio..which is the brake booster vacum dude? Link to post Share on other sites
cabrioman 6 Posted May 6, 2009 Report Share Posted May 6, 2009 the little vacum hose goin from the manifold to the fpr mate T it in there Link to post Share on other sites
Antihero1981 8 Posted May 6, 2009 Author Report Share Posted May 6, 2009 ok sweet now i know..........cheers guys!! Link to post Share on other sites
Antihero1981 8 Posted May 7, 2009 Author Report Share Posted May 7, 2009 ok 1 more questioni installed the boost gauge today but its reading about 15psi which seems to be way to high......also on the face of the gauge it has 0-30psi on top and 0-30 on bottom and its reading downwards...have i installed it wrong? Link to post Share on other sites
FishWick 21 Posted May 7, 2009 Report Share Posted May 7, 2009 Everything above 0 is boost. Everything below 0 is vacuum. Link to post Share on other sites
Antihero1981 8 Posted May 7, 2009 Author Report Share Posted May 7, 2009 ok its reading under ?? have not driven it yet ,only started it up....will it move? Link to post Share on other sites
FishWick 21 Posted May 7, 2009 Report Share Posted May 7, 2009 Boost gauges used to read -30 inHg - 0 - 30 psi, but these days they read -30psi to 0 etc which is meaningless. VR6s usually idle at around -18 inHg.Yep, it will go past 0 into boost when you drive it, but where it's sitting at idle sounds OK to me. Link to post Share on other sites
xyber 1 Posted May 7, 2009 Report Share Posted May 7, 2009 the little vacum hose goin from the manifold to the fpr mate T it in there Ive just changed that, for some reason it was ballsing up allsorts, it was running very rich, so down on power, idling very rough and the dial needle was all over the place. Must have been a small air leak, but I couldnt find it?Ended up Ting it from the brake booster nipple and all is fine now and faster than I ever rememberI also swapped all the jubilee clips for Mikalors, which also made a big difference Link to post Share on other sites
Antihero1981 8 Posted May 7, 2009 Author Report Share Posted May 7, 2009 ok...now i undestand....first time i used one of these.......thanks guys. Link to post Share on other sites
jims13 6 Posted May 8, 2009 Report Share Posted May 8, 2009 yeah mines going from the brake booster nipple.. as there are two tess already there.. just take of the green nipple Link to post Share on other sites
craggsy 91 Posted May 8, 2009 Report Share Posted May 8, 2009 I have my schrick coming from that one.....but it might be going so would free it up Link to post Share on other sites
Antihero1981 8 Posted May 8, 2009 Author Report Share Posted May 8, 2009 does it matter which one it comes off? will it give different readings? Link to post Share on other sites
Antihero1981 8 Posted May 8, 2009 Author Report Share Posted May 8, 2009 selling the shrick?how much..lol Link to post Share on other sites
rodney 17 Posted May 8, 2009 Report Share Posted May 8, 2009 i'll give you a tenner for the shrick.... Link to post Share on other sites
xyber 1 Posted May 8, 2009 Report Share Posted May 8, 2009 ive got the boost guage and the cental locking (i think) running from the same nipple and all is fine Link to post Share on other sites
Antihero1981 8 Posted May 8, 2009 Author Report Share Posted May 8, 2009 well its all hooked up to the FPR now , see how it goes , when i tidy up the bay with samcos i might put it somewhere else Link to post Share on other sites
