GraLaw 0 Posted May 15, 2009 Report Share Posted May 15, 2009 Hey all, When you add turbos and super chargers what do you do with the cooling system? What kind of rad do you all use? And how about mk1 and mk2 conversions? What rads are used? Link to post Share on other sites
Charged VR 0 Posted May 15, 2009 Report Share Posted May 15, 2009 Only running 6psi Rotrex and Just got a lower Thermostat and Fan switch and replaced both coolant pumpsNever had a problem Link to post Share on other sites
Antihero1981 8 Posted May 15, 2009 Report Share Posted May 15, 2009 yeah usually standard....but since i have an auto supercharged vr6 i am going to be installing a transmission cooler next week... Link to post Share on other sites
GraLaw 0 Posted May 15, 2009 Author Report Share Posted May 15, 2009 The reason i ask is because my rad has a hole. A new one is too much money for me right now. What I was thinking is if people can add high pressure and not change the system greatly why can't I find a substitute even if it's slightly smaller? Link to post Share on other sites
Antihero1981 8 Posted May 16, 2009 Report Share Posted May 16, 2009 i am sure you can pick up one pretty cheap from a broken vr Link to post Share on other sites
VR6 Turbo 0 Posted May 16, 2009 Report Share Posted May 16, 2009 VR one will work perfect Link to post Share on other sites
Charged VR 0 Posted May 16, 2009 Report Share Posted May 16, 2009 I can sort you out a good second hand radiator for £30, Im in Iver near Uxbridge if your interested PM me Link to post Share on other sites
rodney 17 Posted May 16, 2009 Report Share Posted May 16, 2009 Hey all' date=' When you add turbos and super chargers what do you do with the cooling system? What kind of rad do you all use? And how about mk1 and mk2 conversions? What rads are used?[/quote']yup you need a full and working rad for those options. you dont need to do anything special. the thermostat change is a good idea.Mk 2 conversions tend to use 'Raddo and their fans as slim fit.if your're going for the turbo or charger options or even mk2 swaps there are how to guides in the premium members sections Link to post Share on other sites
GraLaw 0 Posted May 17, 2009 Author Report Share Posted May 17, 2009 Thanks people but I just run into another problem......http://www.vr6oc.com/e107_plugins/forum/forum_viewtopic.php?287317 Link to post Share on other sites
