MarkGolf 6 Posted May 16, 2009 Report Share Posted May 16, 2009 I got my Walbro from stealth which included their adapter...They said to give them a call when I go to fit it but they're closed now..Logic says you fit the rubber sleeve to the pump and then slide this into the adapter and position in the swirl pot, is this the correct way? Can't really get the filter on without some difficulty this way thoguh..Cheers VR6Pete 1 Link to post Share on other sites
johnODB2vr 1 Posted May 16, 2009 Report Share Posted May 16, 2009 UNLUCKY PUNK ! VR6Pete 1 Link to post Share on other sites
Charged VR 0 Posted May 16, 2009 Report Share Posted May 16, 2009 What Filter are you trying to fit onto it? If you are fitting the pump into the standard swirl pot then you dont use the small bag filter Link to post Share on other sites
matty.vrt 120 Posted May 16, 2009 Report Share Posted May 16, 2009 I bought one took one look and put it back in the box f*ck nows how ya fit it. Link to post Share on other sites
CALICO 130 Posted May 16, 2009 Report Share Posted May 16, 2009 jim potter has one fitted to his car maybe he could let you know Link to post Share on other sites
Charged VR 0 Posted May 16, 2009 Report Share Posted May 16, 2009 I also used the old fuel pump outer casing to create a sleeve for the walbro as it is slightly too small for the Housing, Just make sure the pump never runs dry, try to not go under 1/4 of a tank as 30seconds of dry running will kill th pump Link to post Share on other sites
MarkGolf 6 Posted May 17, 2009 Author Report Share Posted May 17, 2009 Cheers, don't fancy pulling the old pump apart but if I must, I'll do it!Anyone know what order the bits go as such? Got the old siwrl pot apart now and can fit the pump in but it just doesn't seem right. The metal sleeve is at the bottom but it feels like it should slide down deeper but it doesn't.. grr Link to post Share on other sites
matty.vrt 120 Posted May 17, 2009 Report Share Posted May 17, 2009 Some one should do a welbro in tank fuel pump upgrade, how to fit guide thingy. Link to post Share on other sites
Charged VR 0 Posted May 17, 2009 Report Share Posted May 17, 2009 Where in south London are you? I can have a look if you want and show you how i fitted mine. im in Iver near uxbridge Link to post Share on other sites
MarkGolf 6 Posted May 20, 2009 Author Report Share Posted May 20, 2009 I've now fitted it after some advice from Stealth..Bit of a bodge but it works.. Went and got 12 litres of petrol and topped the car up and the pump works a treat.Just need to work out why I have no power to the injectors now!I took pics along the way so I'll get a little DIY up at some point! Link to post Share on other sites
craggsy 91 Posted May 20, 2009 Report Share Posted May 20, 2009 I've now fitted it after some advice from Stealth..Bit of a bodge but it works.. Went and got 12 litres of petrol and topped the car up and the pump works a treat.Just need to work out why I have no power to the injectors now!I took pics along the way so I'll get a little DIY up at some point!The DIY would be great as I might have to go this route soon Link to post Share on other sites
MarkGolf 6 Posted May 21, 2009 Author Report Share Posted May 21, 2009 Right, I got this done and took some pics so hopefully this'll help some people out and get me through my morning at work..The kit as purchased from StealthTook the pump assembly apart before I took pics so no pics of that but it's straight forward enoughBits spread outYou have to 'modify' a rubber cap so it becomes a sleeve, this is to make up for the smaller girth of the pumpYou then have to remove a sleeve from the recirc fuel filter, this is what is basically going to be supporting the fuel pumpHere I put some cable ties on just to make sure it doesn't slip outFitted into the recirc filter thing.Where the unit is going back too, i fitted an o ring to get a nice tight fitHeight of the pump in the swirl potI forgot to take pics of this stage but with the metal sleeve you get from stealth, this sits ontop of the pump itself so it's at it's tallest point. This sleeve just keeps the top of the pump in position.It's a good idea to fit the fuel pipe to the outlet now as you won't be able to tighten the clip once you fit the swirl pot lid on.I was going to use a spare bit of braided line I have since i've used this to replace the lines throughout the car but it makes things a bit awkward when trying to refit the pump so I stuck with the factory rubber. The one you get in the kit is too small so don't even bother with that..Once youve got the pump in the swirl pot with the metal sleeve ontop and hose fitted, you can fit the lid!Here I used a normal jubilee as I couldn't get my proper fuel hose clip on due to space restrictions. I used a fuel hose cap as this spreads the pressure of the jubilee, jubilee's tend to not keep a tight even pressure all round from what i've heard so a leak could occur..(i doubt it though)Bang it on and then fit the brass/copper retaining clip. it just pushes in and stops the pump from bouncing upYou may just be able to see it Now you'll have to wire it, I decided to cut the spade plugs off the oem wiring and solder them to the walbro, then heat shrink!All done and ready to fit!! ky_uk and VR6Pete 2 Link to post Share on other sites
sharky_70 0 Posted May 21, 2009 Report Share Posted May 21, 2009 good stuff! thread needs pinning to be honestmight have to come and fit mine for me in the summer!a thought about your injectors - are they the right impendence? Link to post Share on other sites
MarkGolf 6 Posted May 21, 2009 Author Report Share Posted May 21, 2009 Is an easy job now I've been told how to do it, left my fuel pump out in the garage so all the fuel evaporated so was a clean job too Link to post Share on other sites
sharky_70 0 Posted May 21, 2009 Report Share Posted May 21, 2009 ah i see, thought you'd done VRT Link to post Share on other sites
MarkGolf 6 Posted May 21, 2009 Author Report Share Posted May 21, 2009 no no, want to get it running first, check it's all good then I'm fitting a turbo. Having enough headaches without the extra of having fitted a turbo so glad I haven't done it yet! lolDid plan to R32 it in the coming winter but cba with the hassle on this car. Just going to get it running, show it, turbo it when it's running good and then be done with it Link to post Share on other sites
Ben Seabrook 4 Posted May 21, 2009 Report Share Posted May 21, 2009 Great write up mate thanks good stuff! thread needs pinning to be honesthave made it a how to guide in the knowledge vault Link to post Share on other sites
MarkGolf 6 Posted July 9, 2009 Author Report Share Posted July 9, 2009 I've just been told that on the VW part of the loom, the yellow wire is earth and black wire is live! Link to post Share on other sites
VR6Pete 1,455 Posted November 10, 2015 Report Share Posted November 10, 2015 nice write up will come in handy when replacing my pump in my corrado! Link to post Share on other sites
RBPE 198 Posted November 13, 2015 Report Share Posted November 13, 2015 Nice - not pinning it mods as a DIY? VR6Pete 1 Link to post Share on other sites
VR6Pete 1,455 Posted November 13, 2015 Report Share Posted November 13, 2015 Nice - not pinning it mods as a DIY? Done - was on my mobile the other day Link to post Share on other sites
ky_uk 304 Posted November 15, 2015 Report Share Posted November 15, 2015 Nice write up its gonna come in handy for me Link to post Share on other sites
Mk3highline 287 Posted November 25, 2015 Report Share Posted November 25, 2015 I just made the mistake of thinking the black wire was Earth lolI was thinking of getting a uprated pump but I've been told by a few that you need to keep at least 1/4 tank fuel others wise there is a chance of the pump running dry??? Just spoke to glenco and they will have a direct replacement available in a couple of months Also found thishttp://fuelperformance.co.uk/index.php?route=product/product&product_id=1751 Link to post Share on other sites
VR6Pete 1,455 Posted November 25, 2015 Report Share Posted November 25, 2015 I just made the mistake of thinking the black wire was Earth lolI was thinking of getting a uprated pump but I've been told by a few that you need to keep at least 1/4 tank fuel others wise there is a chance of the pump running dry??? Just spoke to glenco and they will have a direct replacement available in a couple of months Also found thishttp://fuelperformance.co.uk/index.php?route=product/product&product_id=1751That's correct mate. Have to keep 1/4 tank so prevent surge and running lean. Never heard of that brand to be honest. Unsure on reliability though! Will ask around see what feedback is like, although too late as I have ordered a Walbro now. Link to post Share on other sites
dubspy 19 Posted December 1, 2015 Report Share Posted December 1, 2015 I just made the mistake of thinking the black wire was Earth lolI was thinking of getting a uprated pump but I've been told by a few that you need to keep at least 1/4 tank fuel others wise there is a chance of the pump running dry???Just spoke to glenco and they will have a direct replacement available in a couple of monthsAlso found thishttp://fuelperformance.co.uk/index.php?route=product/product&product_id=1751 That looks good.. be good to hear some positive reviews about it as above not heard of it prior.. Link to post Share on other sites
