Tinks 0 Posted May 27, 2009 Report Share Posted May 27, 2009 Hi iv been looking into turboing my vr6 and came across this kit on ebay http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=270356015629&sspagename=STRK%3AMEWAX%3AIT&viewitem=, looks pretty good just wanting sum professional advice on it, any comments welcome thanks,tinks Link to post Share on other sites
rigs 0 Posted May 27, 2009 Report Share Posted May 27, 2009 Smells disturbingly cheap.Though, off the top of my head: - No means to lower the compression of the engine - On standard injectors you're stuck at 250hp anyway - No software to run it - Dunno if the stock fuel pump is up to itIf it looks too good to be true... it normally is. Link to post Share on other sites
thegoth 5 Posted May 27, 2009 Report Share Posted May 27, 2009 and of course being an american kit the manifold is for lhd Link to post Share on other sites
Tinks 0 Posted May 27, 2009 Author Report Share Posted May 27, 2009 cheers for the reply id be uprating the injectors and fuel pump, also id get it remapped when everything is done, what do you mean about the compression of the engine? Link to post Share on other sites
CALICO 130 Posted May 27, 2009 Report Share Posted May 27, 2009 when running turbos you need to lower the compression ratio by fitting a spacer plate between head and block then you need ARP bolts to bolt it all back down another £200 ish dont know how much the spacer plate is Link to post Share on other sites
craggsy 91 Posted May 27, 2009 Report Share Posted May 27, 2009 Standard compression is 10:1.......you need it down around 9:1.I'm doing this on mine using spacer plate and headgasket and im using supercharger. Want engine to be strong as I can afford Link to post Share on other sites
FishWick 21 Posted May 28, 2009 Report Share Posted May 28, 2009 and of course being an american kit the manifold is for lhdThat's not a problem. Guarantee it will be an ATP clone and they fit RHD cars no problemo! All you need to do is relocate the brake fluid resevoir which is very easy.As for the kit, it seems you get a heck of a lot of stuff for £900! Definitely too good to be true. Link to post Share on other sites
Tinks 0 Posted May 28, 2009 Author Report Share Posted May 28, 2009 thanks kev i thought the manifold would be alright, obviously being for lhd its reversed, to good to be true hey lol, iv looked at a few kits on ebay and this looks by far the best as it got a hell of a lot of stuff, the sellars feedback is 99.1 possitive so must be fine, still just thinking about it at this stage but all in all do you lot think that kit is worth buying? if i went down the turbo route?tinks Link to post Share on other sites
Bobtrude 0 Posted May 31, 2009 Report Share Posted May 31, 2009 sorry mate but I would hate to see a vr6 guy end up with something that doesnt work. My advise: dont buy it, buy a used kit or save for a konetic or a charger of some sort (rotex)IT would be to bad if its just junk and you been fooled. Link to post Share on other sites
Bobtrude 0 Posted May 31, 2009 Report Share Posted May 31, 2009 http://www.vr6oc.com/e107_plugins/forum/forum_viewtopic.php?231150 Link to post Share on other sites
