Hi,
I was wondering of anybody could shed some light on where I should start troubleshooting my electric window problem.
None of the electric window switches are currently working (although were about 1 week ago).
The electric mirror adjustors are not working either.
If I use total closure on the door key, all of the windows apart from the drivers one will open and close correctly.
The drivers window was jamming perviously on closing and would take 3 attempts to fully closed, unless I used total closure on the alarm in which case it always used to close.
Now I am assuming that the problem is most likely in the drivers door, but what should my next step be?
TIA,
Paul
check fuses then remove any obstacles that may be stopping the drivers one from closing fully idremovethe window rubber to see if that makes any difference maybe the window is not lined up correctly in the clamps on the mechanism
