gonna wire up my shrick control box but i need to know the colour codes of
A.the switch wire from ignition switch and
B.the signal wire to the rev counter
obd1 coilpack by the way
cheers
Ignition: Black wire (taken from heated windscreen washer loom under scuttle panel)
Tach signal: Green/black wire (ecu position 22)
Earth: Brown wire (taken from heated windscreen washer loom under scuttle panel)
Better still.....
http://www.venommotorsports.com/library/SchrickVGI268.asp
