supadupagt4 0 Posted June 9, 2009 Report Share Posted June 9, 2009 Guys.. i have this problem with my 6..Imagine if u will.. Ur drivin along at a nice steady pace(30-40) and ur on and off the throttle(gently).. When i gently accelerate, the steering wheel does a slight knock and my steering turns right.. when i back off the throttle, slight knock^ and the steering pulls to the passenger side.. Anyone any ideas??tony. Link to post Share on other sites
mike 6 Posted June 9, 2009 Report Share Posted June 9, 2009 are the wheels tracked and balanced ok? tyres ok?i had this in my old vr6, turned out i had buckled wheel..also could be the camber Link to post Share on other sites
Dave_ciw 507 Posted June 9, 2009 Report Share Posted June 9, 2009 I had the same on my K reg dusty mauve ..................... Turned out to be the bottom arm was gone I suppose there is plenty of poss.....good luck fella Link to post Share on other sites
supadupagt4 0 Posted June 10, 2009 Author Report Share Posted June 10, 2009 the tracking was done last week.. and the problem has come on since then.tony. Link to post Share on other sites
Knightrider 1 Posted June 18, 2009 Report Share Posted June 18, 2009 Could be a lower wishbone bush. Try taking it to a different place and have the tracking checked again - preferably one with the sophisticated kit that is out there now. If your bushes are gone, the wheels will probably end up in a slightly different postion relative to each other than the previous time you had it checked and they will say the tracking is out. If it's only a little, that is probably down to the difference in kit and technician, but if it is a degree or more it would point to a bush. Link to post Share on other sites
