amazak 3 Posted June 14, 2009 Report Share Posted June 14, 2009 Hey guy's just spotted this today, my gear lever kinda wobbles/vibrates when taking off after that all gear changes are fine, could that be engine mounts or gearbox mounts as it has never done this before.Thanks Link to post Share on other sites
amazak 3 Posted June 16, 2009 Author Report Share Posted June 16, 2009 No one? Just to clarify if I take off like a normal driver then there is no wobble, but when I fllor it then it goes wobly..... Link to post Share on other sites
legvw 0 Posted June 16, 2009 Report Share Posted June 16, 2009 Could be engine mounts. Pop ya bonnet, with the car runing, get someone to look at your engine while you lift up clutch in 1st gear-just rock on an off the biting point to see if theres alot of movement from the engine. Probably be the front 1 if its gone, i'd go with a vibratectics if it needs replacing mate Link to post Share on other sites
UKG Grant 1 Posted June 26, 2009 Report Share Posted June 26, 2009 could it not be your linkages are a bit worn and you haven’t rely noticed it till that day? Link to post Share on other sites
H13VYY 0 Posted June 26, 2009 Report Share Posted June 26, 2009 mine slightly wobbles, but i only feel it when i keep my hand on the gearstick. Link to post Share on other sites
Rikki 2 Posted June 26, 2009 Report Share Posted June 26, 2009 Mine wobbles back and forth only in 1st not in any other gear? Link to post Share on other sites
jasonoldy69 1 Posted June 26, 2009 Report Share Posted June 26, 2009 mine slightly wobbles' date=' but i only feel it when i keep my hand on the gearstick. [/quote']same Link to post Share on other sites
amazak 3 Posted June 26, 2009 Author Report Share Posted June 26, 2009 Mine wobbles back and forth only in 1st not in any other gear?Exactly that only 1st gear. Maybe it is a common thing? Link to post Share on other sites
Rikki 2 Posted June 27, 2009 Report Share Posted June 27, 2009 Could be check a few of the nwdubs boys see if they have the same? although i do have a knock/clunk could be a mount? Link to post Share on other sites
