Hairyarse 0 Posted June 16, 2009 Report Share Posted June 16, 2009 Got VAG COM and cable and run on my VR. Got the following reportVAG-COM Version: Release 409.1-USChassis Type: 1H - VW G/J/V Mk3Scan: 01,02,03,08,15,25,56-------------------------------------------------------------------------------Address 01: Engine Controller: 021 906 256 Component: MOTRONIC M3.8.1 HS V02 Coding: 00000 Shop #: WSC 013151 Fault Found:00553 - Mass Air Flow Sensor (G70) 31-10 - Open or Short to Ground - IntermittentReadiness: N/A-------------------------------------------------------------------------------Address 03: ABS Brakes Controller: 3A0 907 379 A Component: ABS/EDS ITTAE 20 GI V00 Coding: 03604 Shop #: WSC 00000No fault code found.Can anyone tell me what the Mass Air Flow Sensor is/does? Does this mean I need to replace it?Also, scan ended with error message saying need to register software with author. Is that normal?Any help appreciated CheersAndy Link to post Share on other sites
russj249 2 Posted June 16, 2009 Report Share Posted June 16, 2009 The mass air flow meter detects how much air is going past it. It's like heating a small wire to a constant temperature. Obviously the more and more dense the air is going past it, the more it tries to cool it, meaning more power is needed to keep it at a constant temp.They are very common to play up on the VR's.It might be worth using some electrical contact cleaner first. You can get this from halfords, maplin etc Would recommend trying that before getting a new air flow meter. Spray it carefully inside the air flow meter.. on the metal wire bit. And also the 4 pin plug.Have you got an air filter that you have to oil? Such as K&N or Ram-air? These are the biggest problems for the mass air flow sensor.And yes, it came up with have to register software too. Just ignore that Hope this helps a bit, Link to post Share on other sites
thegoth 5 Posted June 16, 2009 Report Share Posted June 16, 2009 also just try toclear the error ans see if it comes back. Might be that someone has unplugged it in the past and not cleared the error at that time. Link to post Share on other sites
Hairyarse 0 Posted June 16, 2009 Author Report Share Posted June 16, 2009 Cheers for the tips chaps, Standard air filter so that shouldn't be the issue Link to post Share on other sites
Hairyarse 0 Posted June 19, 2009 Author Report Share Posted June 19, 2009 Another question, can you do anything else with VAG COM or do you just auto-scan for faults? Link to post Share on other sites
craggsy 91 Posted June 19, 2009 Report Share Posted June 19, 2009 Can check all sensors are working, how much air is going into engine etc etc....you can do quite a bit with mk3. Even more on mk4 platform Link to post Share on other sites
Hairyarse 0 Posted June 19, 2009 Author Report Share Posted June 19, 2009 Is it obvious how to do that (can you tell I've not messed with it much yet?) Link to post Share on other sites
craggsy 91 Posted June 19, 2009 Report Share Posted June 19, 2009 Oh I run version 805.4 Link to post Share on other sites
craggsy 91 Posted June 19, 2009 Report Share Posted June 19, 2009 just play around with it....cant do anything to the car to hurt it Link to post Share on other sites
Hairyarse 0 Posted June 19, 2009 Author Report Share Posted June 19, 2009 Thats cool, was worried I might screw it all up! I've got version 409 something, is that much different? Link to post Share on other sites
craggsy 91 Posted June 19, 2009 Report Share Posted June 19, 2009 Oh yes......i bought full version from ross tech. Seemed easier than faffing around with trying to get ebay cables working Link to post Share on other sites
Hairyarse 0 Posted June 19, 2009 Author Report Share Posted June 19, 2009 Fair dos, I'll faff around with my ebay cable a little while longer then! lol Looks like you have a bit more bhp to look after than me Link to post Share on other sites
Hairyarse 0 Posted June 21, 2009 Author Report Share Posted June 21, 2009 Plugged in again today and cleared all fault codes. They've not reappeared so that's good. However, another one has come up, no 533. I have found following on interweb; 00533 - Idle Speed Regulation: Adaptation Limit (Add) ExceededPossible Symptoms * Bad Fuel Economy Possible Causes * Air Leak between Mass Air Flow (MAF) Sensor and Engine * Injector(s) faulty * Fuel Pressure Regulator faulty * Throttle Body faulty * Intake Air Filter dirty Possible Solutions * Perform Throttle Body Adaptation * Check Hoses and Pipes to/between Components * Check Intake Air Filter * Check Fuel Pressure Regulator * Check Exhaust Gas Recirculation (EGR) Valve * Check Injector(s) I don't think I have bad fuel economy, average 25-30 mpg with a fairly heavy right foot. So is this anything to worry about?Any advice welcome CheersAndy Link to post Share on other sites
Hairyarse 0 Posted June 23, 2009 Author Report Share Posted June 23, 2009 BUMP - anyone? Link to post Share on other sites
thegoth 5 Posted June 23, 2009 Report Share Posted June 23, 2009 think you should at least do the first two items on the solutions list. the TB adaptes itself if you leave the ignition on without starting the car for 15mins.I'm sure someone will offer to have a look see at inters. we all do like poking around vr lumps ;-) Link to post Share on other sites
baz8328 0 Posted June 23, 2009 Report Share Posted June 23, 2009 How much is the VAG kit and where to get it from ?? Been lookin on fleabay and couldnt believe how many leads and software versions !! Link to post Share on other sites
Hairyarse 0 Posted June 24, 2009 Author Report Share Posted June 24, 2009 Cheers for the help Goth Will be at Inters Sunday so anyone is welcome for a poke around my VR!Baz, I bought this one off ebay http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=300304436216It's for OBD2 but works great, disc comes with it for the softwareCheersAndy Link to post Share on other sites
