hey, my knowledge of vr6 engines isn't so great at the moment so iv got a couple of possible silly questions
i need to get hold of thee aux water up for a corrado vr, however no breakers seems to have one of a 2.9.
so are they the same including fittings etc as the golf vr? so could I intact use one from a 2.8?
if so, I'm not fully sure if the raddos went obd1 and obd2? i have a k reg raddo so I'm not sure which one i would need? or even if it makes a difference
thanks in advance
Grant
just some more silly questions regarding the pump, does it run constantly? or only once the engine is turned off? and is it on the passenger side of the engine at the top on the back? i assume it is the pump thats coursing the noise just like a buzzing/slight grind ish type noise if that makes sense?
