how do i remove the "crack pipe"?
i have so far removed the part that connects to the thermostat housing but i cant get the pipe out from the water pump,there is plenty of play in it but it wont pull out :S
please don't tell me the water pump has to come off? :o
what's the part no for this crack pipe?
As above. This will sound odd but wiggle the pipe and pull towards the battery. You may need to pull it towards the front of the car and break it to get it out. Once you get it out, check that there is no corrosion in the opening it comes out of, if not the new rubber seal can split when refitting the new pipe.
Kevin
