Thundertiger 0 Posted June 25, 2009 Report Share Posted June 25, 2009 Hi all i have removed the passengers air bag in order to fit a glove box on my mk3 vr6. The airbag light is now on, i have used vagcom and it is saying: 1 fault00589-Airbag1: Passenger Side (N131) 32-00 Resistance too high.I have worked on another golf without the passengers airbag as standard and nothing is pluged into the plug behind the dash, so i have unpluged my old airbag and removed it but i cant get the light to go out ( i have reset the light with vagcom and it comes back on)ANY IDEAS ????????Thanks.... Link to post Share on other sites
Charged VR 0 Posted June 25, 2009 Report Share Posted June 25, 2009 I think you will need a deactivation kit from Vdub, Comes with a little resistor that makes the airbag control unit think that the airbag is still there Link to post Share on other sites
Thundertiger 0 Posted June 26, 2009 Author Report Share Posted June 26, 2009 Hi Thanks for that i thought as much. Do you know the value or the resitor required and is it as simple as putting a resistor across the two pins in the plug (passengers air bag) as i suspect thats all thats involved.Thanks again... Link to post Share on other sites
Thundertiger 0 Posted June 28, 2009 Author Report Share Posted June 28, 2009 HI Thanks for your help, I have fitted a 47ohm 10w resistor between the two pins on the passengers air bag plug, reset the light with vag com and all is now fine...........Thanks again....... Link to post Share on other sites
