sharky_70 0 Posted July 1, 2009 Report Share Posted July 1, 2009 whats the stock diameter? 3"?also apart from the gauze on the ends and the sensor in the middle, whats in the housing? Link to post Share on other sites
Rikki 2 Posted July 1, 2009 Report Share Posted July 1, 2009 Nothin....if you remove the sensor its just a plastic tube with the gauze at one end!! Link to post Share on other sites
CALICO 130 Posted July 1, 2009 Report Share Posted July 1, 2009 and you can push the gauze out fromthe inside then you have a round tube lol Link to post Share on other sites
sharky_70 0 Posted July 2, 2009 Author Report Share Posted July 2, 2009 ok cool, so if i was to relocate the sensor all id have to make sure is that the pipe was the correct diameter? Link to post Share on other sites
11redrex 0 Posted July 11, 2009 Report Share Posted July 11, 2009 ...and that you had somewhere to screw it onto, that it made an airtight seal, and wasn't affected by any other heat sources, and couldn't get contaminated. Link to post Share on other sites
CALICO 130 Posted July 11, 2009 Report Share Posted July 11, 2009 doesnt even have to be the same size as you can get 4" ones made but these ar more for charged carsi would think the actual limit is done by the wiring keep the standard maf and extend the wiring Link to post Share on other sites
sharky_70 0 Posted July 11, 2009 Author Report Share Posted July 11, 2009 cheers guysits more so i can have a single unbroken induction tube running from the intake to the TB Link to post Share on other sites
CALICO 130 Posted July 11, 2009 Report Share Posted July 11, 2009 Wheres your intake then? Link to post Share on other sites
sharky_70 0 Posted July 13, 2009 Author Report Share Posted July 13, 2009 sorry, meant the induction intake Link to post Share on other sites
