Coyney26 0 Posted July 2, 2009 Report Share Posted July 2, 2009 Any advice on changing rad? And how much?? VW said £130...... Is there any other common faults to keep my eyes open for? i changed aux water pump, hd leads,sparks,coilpack, numerous hoses but im always getting a spray from rad or somewhere down there on to my coil pack and sparks causing missfires and stuttering! Its cut out dead on me aroubd 5 times this week???? am i looking at rad or summut BIGTIME??????? ANY HINTS PLEASE GET BACK ASAP Link to post Share on other sites
Ben Seabrook 4 Posted July 2, 2009 Report Share Posted July 2, 2009 it will be the thermostat housing mate - a common place for them to leak from and luckily a relatively cheap and easy fix mate Link to post Share on other sites
Coyney26 0 Posted July 2, 2009 Author Report Share Posted July 2, 2009 aaaa cheers mate i will have a look before i split with my cash! i hope it is this if not il pull my hair out! Link to post Share on other sites
djmorgz 0 Posted July 2, 2009 Report Share Posted July 2, 2009 like already said m8 will more than likley be the thermo housing from what i gather there quite common to leak both of ma vr6 have gone at some pointdj Link to post Share on other sites
Coyney26 0 Posted July 10, 2009 Author Report Share Posted July 10, 2009 took it apart and found it was the rad! Tiny hole blowing coolant into fans, changed it and fan belt and now she running sweet as a nut! If your rad goes you can do yourself, slide it out from the bottom,we didnt even have to disconnect the air con! Happy days Link to post Share on other sites
