Hi everyone, haven't been on for a while..
While I've been away, I have had a few things done.. new air filter and 6 branch manifold and new exhaust..
it was running 180bhp before i did anything to it.
now with de-cat, wrapped manifold, new exhaust and cone air filter, what power do you think I should expect, and most of all. Will it be more beneficial to have it remapped?
I know storm and a few others can do the re-maps, so just want an idea of cost, and estimated BHP increase on a standard car.
Cheers
well the MAF and Lambda should allow for the change in flows and run within the preset zones.
You can get it mapped but you will not get much more out of it. That said keep an eye on your exhaust pipe on a run and it should be nice and clean.l If it carbons up then you may need to look at sensors and then a remap may be worth while especially if you are running a dizzy as they tend not to adjust just quite as well ....
