J-GTi 0 Posted July 30, 2009 Report Share Posted July 30, 2009 Hi Folks,First off, car is a 97 highline with a vortech v9 'charger.Have a slightly confusing problem, under hard acceleration in 1st gear (only 1st any other gear is fine *-) ) the car will splutter and cut out for a split second, clocks and light's turn off and back on too.Seems to be an electrical problem going by the electrics turning off but after poking around the engine bay for a while today I didn't spot any loose or worn wires.It won't do it if you pull away normally but as soon as you attempt to give it a little stick it'll pop as if it's misfiring and you'll see the light's/clocks turn off and back on. As I said it'll only do it in firts gear, I'v noticed the rear mount seems to have a bit of play which could be causing it to rub against some wiring and cause a short but as I said I didn't spot anything.Any ideas or suggestions?Sorry if this has been asked before but I couldn't find anything after loads of searches.Thanks John Link to post Share on other sites
