cabrioman 6 Posted February 5, 2012 Author Report Share Posted February 5, 2012 How much work did your turbo need? its gone for a full rebuild, the guy thinks it was a oil feed problem, thinks it may have had to much pressure so he`s going to check it out and supply me with a new oil feed line with a restrictor in it Link to post Share on other sites
russj249 2 Posted February 5, 2012 Report Share Posted February 5, 2012 Can't remember' date=' 12 or 11 12point socket?Think you caught that at the right time mate, I've seen cranks eat into blocks when the thrust washers fail!Glad you've got the love back fella [/quote']cheers dude will get a couple of new sockets ...They're American.. they're 1/2 inch imperial 12 point socket Link to post Share on other sites
legvw 0 Posted February 5, 2012 Report Share Posted February 5, 2012 Oh well, wasn't far out lol! Link to post Share on other sites
bungy 2 Posted February 5, 2012 Report Share Posted February 5, 2012 Have you got a picture of your sump with the oil return line ? Link to post Share on other sites
cabrioman 6 Posted February 5, 2012 Author Report Share Posted February 5, 2012 by the sounds of it the oil return was in the wrong place aswell so not done to well !! lol .... going to get it welded up and put the return in the block just below the turbo so have to drill and tap it .... Link to post Share on other sites
cabrioman 6 Posted February 9, 2012 Author Report Share Posted February 9, 2012 first thing ticketed off the list .... Turbo Rebuild Done. Link to post Share on other sites
legvw 0 Posted February 10, 2012 Report Share Posted February 10, 2012 Nice.... Link to post Share on other sites
cabrioman 6 Posted February 10, 2012 Author Report Share Posted February 10, 2012 looks all nice a new and shinny shinny ....pics later ... Link to post Share on other sites
cabrioman 6 Posted February 12, 2012 Author Report Share Posted February 12, 2012 turbo mmmmmm Link to post Share on other sites
Caddyslammed 16 Posted February 12, 2012 Report Share Posted February 12, 2012 I'm really looking forward to seeing this up and runnng again mate Link to post Share on other sites
cabrioman 6 Posted February 12, 2012 Author Report Share Posted February 12, 2012 you got a long time to wait mate lol but it will be worth it !!! lol Link to post Share on other sites
jims13 6 Posted February 12, 2012 Report Share Posted February 12, 2012 wernt your return in the same place as mine.. or was it at the fornt of the sump..as for the turbo feed .. id alwys use a restrictor, the quickest way to kill a turbo especialy a ebay one is to give it to much oil .. glad you have got it sorted though Link to post Share on other sites
cabrioman 6 Posted February 12, 2012 Author Report Share Posted February 12, 2012 the return was at the back of the sump about half way up ..... getting it welded up and going to put a union in the block and run it that way ... Link to post Share on other sites
legvw 0 Posted February 12, 2012 Report Share Posted February 12, 2012 By the looks of your sump mate, the hole was far too small, wanted to be at least 19mm. Link to post Share on other sites
cabrioman 6 Posted February 12, 2012 Author Report Share Posted February 12, 2012 ah you got it jolly good ....oh really hmmm what you think just make it bigger then or weld it up and put the return in the block ???? Link to post Share on other sites
hvr6 88 Posted February 12, 2012 Report Share Posted February 12, 2012 turbo mmmmmmthis looks niiiice Link to post Share on other sites
legvw 0 Posted February 12, 2012 Report Share Posted February 12, 2012 ah you got it jolly good ....oh really hmmm what you think just make it bigger then or weld it up and put the return in the block ????Best place is into the block, but in the sump is ok. As standard, a 20v 1.8t has its oil return low in the sump. Link to post Share on other sites
cabrioman 6 Posted February 12, 2012 Author Report Share Posted February 12, 2012 ok cool could you just weld it up for me buddy and ill put it in the block .... Link to post Share on other sites
legvw 0 Posted February 12, 2012 Report Share Posted February 12, 2012 No probs Link to post Share on other sites
cabrioman 6 Posted February 12, 2012 Author Report Share Posted February 12, 2012 cheer bud .... Link to post Share on other sites
cabrioman 6 Posted February 17, 2012 Author Report Share Posted February 17, 2012 Well here is my small list of work to do over the next few months ....Rebuild Turbo,Rebuild Engine using H beam Rods and Low Comp Pistons,Rebuild Gearbox or replace with better,Sort out wiring in engine bay, chaffed wiring etc etc,Replace Rear engine mount,New Oil cooler lines,Remove and sell light weight pullies,Relocate turbo oil return line from sump to block,Sort out bolts for front engine/gearbox mount,Heat proof turbo jacket,Heat proof turbo oil and coolant lines,Longer oil feed line with restrictor valve,Weld up unused holes in bulk head,Heat proof bulk head,Swap Turbo to down pipe bolts for studs,Replace prop shaft front rubber joint,Fit fuel rail upper bolts, drill and tap manifold,Replace PAS metal lines for rubber/braided lines,Fit MK4 4mo clutch master cylinder and lines,Replace belt tensioner or re-cut threads,Lock-tite ARP flywheel bolts, Delete small water out let on crack pipe,Replace small water outlet on block or normal core plug,Weld up Crack in exhaust manifold and head wrap,Remove and sell dash,Other jobs if i get time,Make car lighter - cut out insides of doors, tailgate, remove any more unneeded loom, remove any more unneeded metal brackets etc etc from insideRemove all under seal, Refitt old fuel tank or fitt 4mo/syncro one ,Remove roof vent and cover roof in carbon sheet,Replace side sills,Paint complete car,Plenty to be getting on with !!! Link to post Share on other sites
VR6Nat 9 Posted February 17, 2012 Report Share Posted February 17, 2012 Only a days work there mate. Get on it!! Link to post Share on other sites
cabrioman 6 Posted February 17, 2012 Author Report Share Posted February 17, 2012 well maybe a day and half with a few coffee breaks and a bacon roll ..... !! lol Link to post Share on other sites
spadam 7 Posted February 17, 2012 Report Share Posted February 17, 2012 The way you work you will have it done in a morning then you can pop down here and help me out. Link to post Share on other sites
J5KE F 0 Posted February 18, 2012 Report Share Posted February 18, 2012 did u say u want some bits cutting out.....????? ;-) Link to post Share on other sites
