Hi all,
I have a pretty bad water leak and from what i can tell it is coming from this thing
Can anyone tell what this is?? It is sitting underneath the crank pipe, which has now been replaced, and after much work, and many leaks fixed I still have this one. If I had haor i would be pulling it now!!
Thanks
John
Hi thanks for the quick reply, I have checked the little rubber pipe that goes from the crank pipe to the oil cooler, and it seem fine, but it looks like the water is leaking from the sides of the oil cooler. could the oil cooler be cracked and leaking?
thanka
John
