Pete's OBD2 Corrado VR6 - On The Road
  • Replies 509
Popular Posts
It's alive!!!
Went to my local pirtek branch to make up my oil lines as didn't have correct tools here to do the job and wanted peace of mind 🏻 They have done a great job and only £38 - I supplied the li
I went to Stealth yesterday, feeling quite apprehensive! I am the 3rd car that has used their new strapping system, so they can run higher power cars without needing to use glue all of the time, and a
Posted Images
Well I thought I'd post up the progress for the day!
Early start this morning, ready for action!
It didnt take long before Tony set to work :)
Say cheese... Tony's standard pose
Engine has seen better days to be honest!
sheeeet! it's gone!?!
ahhh, there it is :) didnt take more than an hour to whip out!
the start of stripping the engine..
head gasket defiantly has failed... im pretty sure my finger should not be there...
surprisingly, the bores are in pretty good condition, honing marks still visible....
Thanks to Eastwood John popping over to lend a hand :) Head being cleanedup..
head is now looking better...
same treatment for the block.
meanwhile... the head was being stripped to replace valve stem seals, and new hydraulic lifters..
Ceramic coated raceland manifold fitted.
new timing chains fitted...
I sorted out the intake stuff ready for fitting...
New thermostat housing / crack pipe / thermo stat fitted... (new waterpump fitted earlier in the day)
ARP headbolts being torqued up, unfortunately one of the nuts fell down into the timing chains, so had to remove gearbox again to retrieve it which put us back a little...
Well, we called it a day then... beer to drink, Chinese to eat, and a shit boxing match to watch :)
We had some issues with some bolts snapping, and the biggest pain the arse was the rear engine mount bolt snapped, so cant get the engine in this weekend, until a new one has arrived... or my mate's neighbour has success removing the snapped bolt from the current mount :(
Tomorrow... heater matrix / coilovers, finish engine off. going to give it all a jet wash along with the engine bay while its all out too...
Laters :)
glad to av met you pete,
nice to see you again tony, hope ya got home safe,
+ glad to have met you jay,
rearly glad to have come over this w/end and helped out, head spinning though abit on saturday lol,
next date 27th ok for then mate, are you painting on that day, sounds like a job for shell lol,
thanks again pete,
Ok....next update for you all folks :) today was a late start in comparison to yesterday, with a lovely fry up thank to my lovely other half.
So, we got the Coilovers on first of all.
I needed to shave some off the callipers to squeeze the Brock B2's on the front... this turned out to more than I thought!! Sooooo, i'm going to try the wheels on a Golf tomorrow to see if the 288mm brake setup will be a better option...
John and Jason came over today to lend a land with getting the dash out to replace the heater matrix.... Thanks very much guys :)
Rear coilovers on... and rear brock B2's fitted....
It wouldnt be the same if there wasnt a cheesy photo of Tony in the set, so here it is!
ahhhh, here's the offending article! goosed!
and here is the car stripped out... didnt take long at all at this point :)
new matrix ready to rock and roll
now on the ground... note that no engine is fitted, and ride height is yet to be adjusted..... 58mm, front 57mm is what I am going for :)
That's it for this weekend.... will next play in 2 weeks time when the engine can go back in...
Few items needed as a result of age / damage etc.... will get these over next couple of weeks :)
Adios for now amigos! and lastly, special thanks to Tony for all his hard work (and for putting up with Eastenders and coronation street on Friday night ;) )
glad to av met you pete' date='
thanks again pete,
you too mate! Although you need to drink more brews (not home brew either lol)
tony has just txted me, hes just got home safe and sound.... will be 27th / 28th getting it all back together, and want to hammerite the cross member / engine block / any other rusty bit lol... so bring a wire brush with ya :) oh and gotta finish the dashboard off / ride height / tidy up engine bay... then should be all good!
thanks again for your help this weekend matey.
good day all round pete' date=' happy to help out mate ;-)
nice to meet you as well john ,will give you the list of jobs i need doing tony lol
thanks again mate :) hope you can make it in a couple weekend's time to get it finished up :D really good weekend's progress :)
