Pete's OBD2 Corrado VR6 - On The Road
  • Replies 509
Popular Posts
It's alive!!!
Went to my local pirtek branch to make up my oil lines as didn't have correct tools here to do the job and wanted peace of mind 🏻 They have done a great job and only £38 - I supplied the li
I went to Stealth yesterday, feeling quite apprehensive! I am the 3rd car that has used their new strapping system, so they can run higher power cars without needing to use glue all of the time, and a
Posted Images
Ok, thought I'd do a bit of an update. i've been busy with work, and ill kids! so only just getting time now!
Well we cracked on the other Saturday, myself, tony, John and Jason (thanks guys!)
so first, we got the new brake line in, made up from original green steel for that factory look, and went ahead with the goodridge hose fitting :)
also got a new rear VW badge :)
also fitted new crank pulley... under drive OBX jobby.
178998_501880831903_265372491903_5898017_2299583_n.jp
so put most of the dash back in, and replaced oil cooler seals as they were shot and leaking...
replaced bonnet cable.... and did some electrical repairs on the fog light wiring.
got the car on all 4's but ran into problems with the front wheels so decided to put the standard alloys on for now!
discovered that it was rather low!
unfortunately, the rear brake lines had seen better days!
so i've got my man to make me up some more new ones in green steel.
also had a problem with the demister bowden cable being ragged so need to order a new one! (only £9 + VAT) then I can get the heater controls back in.... also fitted a new heater motor while we were at it!
Today, I had a mate around with his orbital polisher thingy!
gave it a good wash off, 2 years worth of crud!
masked up some bits and bobs;
here's some before shots:
some after shots:
Well thats it for now.... will post more updates when I have them... finishing off with the bodywork tomorrow.... and waiting on other parts before i can continue and get it in for an MOT!
its still not finished mate' date=' only done half the car :)
started at about half 1 and finished for the night at 8! really impressive stuff, he used this stuff;
[img']http://a1.sphotos.ak.fbcdn.net/hphotos-ak-snc6/180170_10150402043195422_571465421_17032338_5563568_n.jpg
I was just about to buy this kit from a site in detailing world..
So you rate it well then mate?
  • 2 months later...
it's been a while since I've put an update on here, been a little busy with work and all that sort of stuff.
Today, I got the brake lines on, bled up the system, and troubleshooted the ABS problems I've been having as the light does'nt come on at all, and I was getting comms issues using VCDS....
I replaced the ABS ECU, obtained a new ABS Lamp, still had the same issues, It seems that the replacement ABS lamp also had a blown bulb, and it would appear VCDS has a software bug, as older version of VAG-COM talk to the ECU just fine!
I tested the ABS by attaching a side repeater bulb to the terminals, and it came on and off as expected, so i am now on the hunt for a new bulb to solder in the unit...
Continued to set the coil-over ride height, and spray the coilovers with chain wax to protect them, sorted a blow on the exhaust joints but the centre silencer has developed a hole due to rust, so will need to replace them....
Here's a quick photo of trying to get the car up my drive, its quite steep, so had to make sure ride height was set appropriately :)
I'm now toying with the idea of selling my Brock B2's and looking out for some compomotive mo's again! I really like those, and would do anything to get my old set back! :)
stuff left to do:
Fit side repeater case - Need to order
Fit front drivers brake hose clip
secure fog light cases to bumper
fit new heater bowden cable
finish fitting heater controls
put remaining dash trims back in
tracking / camber etc...
MOT
Fit OBD2 conversion
fit uprated headlight loom
fit a new radiator as have a small leak on mine...
Fit recon gearbox with g60 final drive.
have fun!!!
hey buddy. 2 problems:
1) VCDS uses a different way of communicating with my ABS ECU than the older version of VAG-COM... not looked in detail, but using VAG-COM works fine, I suspect a default setting is different between the 2 versions.
2) ABS Bulb had popped - what made it more of a head scratch was that I bought another ABS light module, which also had a popped bulb, so it looked something more than it was...
Ordered some bulbs from RS components, and with a bit of bish bash bosh, I had 2 working ABS light modules;
Happy days... few more bits to do before I can get it in for an MOT, but mostly there now!
p.s - dont worry about stickers, I put a couple in the post for Dave today for dimensions..
Pete
you could still pop over mate, would speed up things.... as I sent them second class :)
Yeah, it was a known working item, probably damaged in the post, those bulbs are easy to pop!
I verified that it was the bulb by attaching my multimeter to the terminals of the bulb.
On turning the ignition it read 12V, after a few seconds, it dropped to 9v. signifying that it was the bulb at fault.
Just writing up a guide now!
