mk4 manual adjustable haldex controller
Andy from A K Bodycraft sells a haldex controller that mounts in the car, but is similar in control to that of the sqs. You can adjust the valve in car, which is hooked up to a block that bolts on the side of the haldex via 2 hoses. You will just have to run your own power to the pump.
  • 1 month later...
