fastmonkey 0 Posted September 26, 2009 Report Share Posted September 26, 2009 HiBeen to see a mk2 today with a VR6 lump in, car checked out ok, however main area of concern was the sump which had been scraped and what I believe to be the join to the gearbox which looked slightly seperated and leaking oil all be it very slowly. Also the sump area and the like had lots of oil dirt around it so assumed this was pretty normal.Also there was some slight oil deposits on the drivers side edge of the engine. Unfortunately I am not mechanicly minded...(yet.....) so I wanted some advice as to what these faults could be and how serious they are and likely cost of fix ? Hope someone could help ?Here is the drivers side edge of engineHere is the scraped sump Here is the crack/split/break in the sump to gearbox Link to post Share on other sites
craggsy 91 Posted September 26, 2009 Report Share Posted September 26, 2009 Pic 1 needs new rocker cover gasketPic 2 is usual state of lowered sumpsPic 3 looks like part of the cover that sits over flywheel Link to post Share on other sites
DanH 1 Posted September 26, 2009 Report Share Posted September 26, 2009 1 - yea agree with craggsy, and maybe new breather on pic 1 too? (sack it off tho cos its expensive, get one of them pipercross filters or summit...think im right?)2 - yea, thats pretty normal lol they sit low. although that looks pretty dented too.3 - thats fine imo, its jus a cover. bash it back in place, or its only to 10mm bolts that hold it on, take it of and flatten it outany more pics? Link to post Share on other sites
DanH 1 Posted September 26, 2009 Report Share Posted September 26, 2009 hmmmm lookin at them again, id budget for a sump and a new oil pick up just incase...............and did u say oil is leaking out of that gap in pic 3? Link to post Share on other sites
fastmonkey 0 Posted September 26, 2009 Author Report Share Posted September 26, 2009 Thanks for all the quick replies, most appreciated.Yes definately oil leaking from picture 3, not visibly dripping but was gathering around the lowest part and definately would drip given time.Unfortunately I can not fix these things myself so any ideas on parts and labour ?? Link to post Share on other sites
CALICO 130 Posted September 26, 2009 Report Share Posted September 26, 2009 Pic one part is about £35 ish normally on EBay from FIRCOF easy to swap yourself rocker cover easy as well not easy to get these wrong so deffo worth trying yourself sump gasket slightly harder but only because its at the bottom i think new sumps are not available from VW any more so probably ebay on that as well Link to post Share on other sites
DanH 1 Posted September 26, 2009 Report Share Posted September 26, 2009 if it were me..................id deffo buy it lolrocker gasket, u can def do that - loads of info on here prob. sump, u can do that, i did mine in the car park at work on lunch hour! Link to post Share on other sites
Phat VR6 3 Posted September 26, 2009 Report Share Posted September 26, 2009 gfs still do sumps. Its hard to tell how much oil its loosing. rocker is hardly anything, If oil is dripping on the floor then you have to worry about it. It could just be a built up over the last 12 years and 100,000+ miles, If its hardly loosing any oil personally i wouldn't bother doing anything.Only thing you have to watch out for is the oil leak on the N/S of the sump (buy the gearbox), this COULD be your crank seal. if its bad then you can get oil on the clutch causing it to slip. to change the crank seal the gearbox has to come off. then while your doing it you will probably end up doing the chains at the same time.take the cover plate off and have a look under it, its its quite clean inside there then happy days. full of oil id take into consideration that the crank seal might need changing.personally id carry on driving it till i was loosing a considerable amount of oil or it was dripping on the floor. then id look further into it. you won't be damaging anything, just costing a few ££ a month in oil Link to post Share on other sites
DanH 1 Posted September 26, 2009 Report Share Posted September 26, 2009 bodge speaks sense. u say its dripping in pic 3, if its dripping from here.......................it could be a bit of a bigger job. anywhere else is fine lol. there a bit of oil down the block i see so could just be oil cooler..... Link to post Share on other sites
Trini 0 Posted September 27, 2009 Report Share Posted September 27, 2009 i've this same problem but i can still engage in any gear. Any ideas wot it coulr really be? cheers Link to post Share on other sites
fastmonkey 0 Posted September 30, 2009 Author Report Share Posted September 30, 2009 Well thanks to all the replies on here I took the plunge and bought the car. I need to use it as a daily for a while so I've booked it straight into a specialist for a once over and get the sump sorted.Now i've had a proper look underneath with someone who knows what they are doing it looks like an impression of the oil pump in the sump cover ! This could mean the oil pump is damaged and is not moving the oil round so I have left it with them to sort out. Link to post Share on other sites
DanH 1 Posted September 30, 2009 Report Share Posted September 30, 2009 well done, good choice! haha!that'll be the oil pick-up....mines got a mark on the inside of the sump where it hit, had a look and was no damage so put it all back together - no probs at all! Link to post Share on other sites
