dru 0 Posted September 28, 2009 Report Share Posted September 28, 2009 Help!!!!! my vr brokedown on the way home and wont start againthis is what happenddrove over a speed bump and chaged from 2nd to 5th put my foot down and the engine just died the dash lights came on and rolled to a stop, tried stating it a few times and the best it would do was splutter to 500rpm max and instantly cut outive run vagcom and 3 faults where found3 FAULTS FOUND00518- THROTTLE POSTION SENSOR (G69) 30-10- OPEN OR SHORT TO B+ - INTERMITTENT17978 - ENGINE START BLOCKED BY IMMOBILIZER P1570 -35-10................ INTERMITTENT00513 - ENGINE SPEED SENSOR (G28) 03-00 - NO SIGNALso i cleared this fault codes disconected the vag turned car off locked unlocked tried to start it again and ran another scan now only 1 fault was found00513 - ENGINE SPEED SENSOR (G28) 03-00 - NO SIGNALany ideas of how to sort it please guys n girls TA dru Link to post Share on other sites
dru 0 Posted September 28, 2009 Author Report Share Posted September 28, 2009 oh and its a mk3 obd1 1995 also if i keep sarting it over and over there is no smell of fuel in the egine Link to post Share on other sites
Ben Seabrook 4 Posted September 28, 2009 Report Share Posted September 28, 2009 The engine speed sensor code always comes up if you check the car without the engine running mate.well I have had a stalling prob on my car and it was the throttle position sensor mate however the problem before was when it wouldn't start at all and that was an immobilizer problem and it came up with the same code you have had - I had to have the ECU re-coded to remove the immobiliser Link to post Share on other sites
dru 0 Posted September 28, 2009 Author Report Share Posted September 28, 2009 it has an after market immobilizer and alarm when the imob kicks in it kills everything wont even try to start could it be the oe imob kicking in ????? probally not relivent but i changed the stereo yesterday that is the only thing on the car i have changed Link to post Share on other sites
Ben Seabrook 4 Posted September 28, 2009 Report Share Posted September 28, 2009 mine was the orginal VW immobiliser that had gone wrong mate - the aftermarket one wont show up on vag-com so if there is an issue it will be the VW one ! Link to post Share on other sites
dru 0 Posted September 28, 2009 Author Report Share Posted September 28, 2009 00518- THROTTLE POSTION SENSOR (G69)30-10- OPEN OR SHORT TO B+ - INTERMITTENTi should have said i was looking at all the different reading it did say the trottle postion was at 13 degrease at normal and went up to 76 when you push the pedal down???? Link to post Share on other sites
dru 0 Posted September 28, 2009 Author Report Share Posted September 28, 2009 mine was the orginal VW immobiliser that had gone wrong mate - the aftermarket one wont show up on vag-com so if there is an issue it will be the VW one !did it even try to start at all? Link to post Share on other sites
Ben Seabrook 4 Posted September 28, 2009 Report Share Posted September 28, 2009 the first couple of times it started ok but got worse until it would tick over but not fire up mate - it can sometimes be the igniton coil which reads the code from the key and sends a signal to the ECU - not too tricky to replace Link to post Share on other sites
dru 0 Posted September 28, 2009 Author Report Share Posted September 28, 2009 probally not relivent again but ive never noticed it before theres a constant buzzing/whinning noise coming from the egine when the ignition is on, from behind the coil pack ( silver cylinder shaped thing with a hose going in to the bottom of it and wires at the top) Link to post Share on other sites
craggsy 91 Posted September 28, 2009 Report Share Posted September 28, 2009 aux water pump Link to post Share on other sites
dru 0 Posted September 28, 2009 Author Report Share Posted September 28, 2009 should it be constantly running? Link to post Share on other sites
thegoth 5 Posted September 28, 2009 Report Share Posted September 28, 2009 yes when the ignition is on and for a short time after running if the engine is hot.when you fitted the stereo did you disconnect anything else? Link to post Share on other sites
dru 0 Posted September 29, 2009 Author Report Share Posted September 29, 2009 no not knowingly Link to post Share on other sites
dru 0 Posted September 29, 2009 Author Report Share Posted September 29, 2009 completley baffled by thi s now still not show ing any faults except for the speed snsor which is working as it gets a signal when its trying to start, got a good spark ive checked all plugs etc no more more immobilizer faults recordedwhere do i start? Link to post Share on other sites
dru 0 Posted September 30, 2009 Author Report Share Posted September 30, 2009 buggerd fuel pump will all be sorted tomorrow but wasnt cheap BAD TIMES Link to post Share on other sites
Ben Seabrook 4 Posted September 30, 2009 Report Share Posted September 30, 2009 ah nice one mate how did you find that out ? Link to post Share on other sites
dru 0 Posted September 30, 2009 Author Report Share Posted September 30, 2009 had to ntake it to a vw specalist to work there magic Link to post Share on other sites
Ben Seabrook 4 Posted September 30, 2009 Report Share Posted September 30, 2009 ah ok mate ! well glad you got it sorted anyway and at least it's not anything too serious Link to post Share on other sites
dru 0 Posted September 30, 2009 Author Report Share Posted September 30, 2009 yea cheers all for ya help Link to post Share on other sites
