NIBSWORLD 0 Posted November 2, 2009 Report Share Posted November 2, 2009 Hi guys,I realy need some help i have a m reg vr6 bought it a few months ago and since ive had it theres a fault with tickover when i first start the car if i dont keep the revs at around 1000rpm it cuts out i have to keep my foot on the accelerator for about 2 minutes or it will keep cutting out after the time has passed it runs fine. If i park up for say an hour or so the same thing happens but if i run to the shops get out and then back in the car it starts fine a friend said it could be my cold start valve any help would be greatNibsworld Link to post Share on other sites
VR6Nat 9 Posted November 2, 2009 Report Share Posted November 2, 2009 Could be your ISV (idle stabilisation valve) mate, take it off and give it a good clean with some contact cleaner and see if that helps.... Link to post Share on other sites
thegoth 5 Posted November 2, 2009 Report Share Posted November 2, 2009 the isv is sturdy enough to use carb cleaner on Link to post Share on other sites
CALICO 130 Posted November 2, 2009 Report Share Posted November 2, 2009 Could also be the throttle position sensor on the side of your throttle body Link to post Share on other sites
