hello
for last couple times i decided to take bowser out in the wet he has developed a misfire.
start up fine leave to warm up and runs abit rough, pull away and its sluggish then all of a sudden the power comes through. its constant until it warms up or been driving for bout half hour.
had the same prob with my mk2 and that was the dizzy, replaced that and it was fine. could this be the same on bowser?
he has had new leads and plugs fitted
I have had the same problem last winter, changed my coil pack leads,plugs and lots of other things. Ran fine all summer upuntil last sat after a day of driving rain then sorted it self next time i drove it, could it be dampness or driving rain going on to my (bmc) air filter ? ?
I've just 'bodged' my coil pack last night. Took it off to find cracks on the top surface and bottom surface, and a couple on the front face, and the little plastic clip on cover was warped letting water in, causing corroison of the contacts under the plastic cover.
I have coated the the entire plastic section with JB Weld epoxy, and also epoxyed the plastic cover.
Hopefully that'll stop it running like a dog when its damp.
This is my hesitation problem (helps if you use head phones).It did it again yesterday after 2 hours of stop start shopping then lfrt it for 2 hours no rain or damp then did this until left it over night.Thought it may be junk in fuel filter but only happens when engaging clutch after and standing start. Any suggestions would be welcomed as it only seems to do it over the winter period.
Arcing - electricity jumps from one place to another through the air.
In the case of a coil pack, you can see 'sparks' flying out from the body of the coilpack onto the HT leads. Normally caused by cracks in the plastic cover to the coilpack.
Check out this vid on Youtube:
I HAVE AN INTERMITTENT MISFIRE ON THE CLOCKS WHEN DRIVING BETWEEN 2000 AND 3000 RPM. Changed the plugs and leads and did seem to run better but clocks still show the misfire. I don't hear any misfire but rev counter flicks about when it happens. Could happen with town or motorway driving. Any ideas?? Coil Pack??
