Lightened flywheel?
I have the Schimmel 9lb flywheel in mine and if the gearbox comes off again, the standard flywheel is going back in.
Yes light flywheels make the motor spin up quicker but the resultant vibration you get in return (more so with stiff mounts) doesn't make it worth it as a daily driver imo. And you usually get a bit of clutch judder with light flywheels aswell.
I have the Schimmel 9lb flywheel in mine and if the gearbox comes off again' date=' the standard flywheel is going back in.
never had these problems maybe u need too check if there is an imbalance have it balanced with pressure plat
(some times with komplet engine rebuild we have pressureplate,flywheel and crank balanced together;)=
