Ive had my vr6 for a year and a half and this time i have not changed or topped up my gearbox oil. So is this a regular thing to do on these cars? If so which oil is best and where do you top it up/drain it?
Also my gearbox is a bit tight when engaging some gears would some oil sort this problem?
may help the crunch.. If your doing a change then you can slick50 the box which adds benefits on higher milers..
The method to change is simple...
car up in the air. Get on your back with a good light/torch and look for the most difficult area to access and you are in the right point. Undo bolt and fill.... :D Njoy...
