Jonnyboy82 0 Posted November 28, 2009 Report Share Posted November 28, 2009 Ive had my vr6 for a year and a half and this time i have not changed or topped up my gearbox oil. So is this a regular thing to do on these cars? If so which oil is best and where do you top it up/drain it?Also my gearbox is a bit tight when engaging some gears would some oil sort this problem? Link to post Share on other sites
CALICO 130 Posted November 28, 2009 Report Share Posted November 28, 2009 my auto is a sealed box and should be serviced every 60,000 dont know about the manual version Link to post Share on other sites
craggsy 91 Posted November 28, 2009 Report Share Posted November 28, 2009 Redline MT 90 is recommended by lots of people for the 02A gearbox. It is same spec as VW use Link to post Share on other sites
Jonnyboy82 0 Posted November 30, 2009 Author Report Share Posted November 30, 2009 So where do i top up the oil? And will this help the light crunching going into gear? Link to post Share on other sites
rodney 17 Posted November 30, 2009 Report Share Posted November 30, 2009 may help the crunch.. If your doing a change then you can slick50 the box which adds benefits on higher milers..The method to change is simple...car up in the air. Get on your back with a good light/torch and look for the most difficult area to access and you are in the right point. Undo bolt and fill.... Njoy... Link to post Share on other sites
craggsy 91 Posted November 30, 2009 Report Share Posted November 30, 2009 Undo the fill hole first in case it doesnt undo after you have emptied the box Link to post Share on other sites
Rikki 2 Posted December 1, 2009 Report Share Posted December 1, 2009 Yea was gonna say the same craggsy. Is the drain hole the vw badge under the box and the fill hole on the side. They take 2 litres by the way! Link to post Share on other sites
Matt W 4 Posted December 1, 2009 Report Share Posted December 1, 2009 Its a 17mm allen key for the drain and fill.The fill is on the "front" of the gearbox and the drain is underneath, they are both like very large grub screws! Link to post Share on other sites
