bobveedub 0 Posted December 10, 2009 Report Share Posted December 10, 2009 hi,for some reason my engine fan come on last night full pelt and now it does it when engine gets up to temperature? my coolant and oil levels are fine, does anyone know what could cause this please?the engine itself isnt that hot, it seems to come on when the oil gets to about 66degrees..Thanks! Link to post Share on other sites
tjsmudger 2 Posted December 10, 2009 Report Share Posted December 10, 2009 is it not the fan regulator, has the perspex casing cracked and water seeped in causing it to fuse, happened to mine. got a replacement from a audi breakers, now works bob on!! Link to post Share on other sites
bobveedub 0 Posted December 10, 2009 Author Report Share Posted December 10, 2009 ahhhh wheres that in the engine bay? cheers! Link to post Share on other sites
tjsmudger 2 Posted December 10, 2009 Report Share Posted December 10, 2009 Under the coolant tank Link to post Share on other sites
bobveedub 0 Posted December 10, 2009 Author Report Share Posted December 10, 2009 cheers mate, just looked and my cover is missing and the 5amp fuse was blown. changed and now looking for a cover, thanks for your help! Link to post Share on other sites
bobveedub 0 Posted December 10, 2009 Author Report Share Posted December 10, 2009 damn its still snapping the 5amp fuses. Link to post Share on other sites
tjsmudger 2 Posted December 10, 2009 Report Share Posted December 10, 2009 you will have to most likely get a replacement fan module, water has most probably got into the unit, mine was soaking inside, not really dear to obtain from a breakers, i got mine from a audi breakers for 15 pound, i will have a look for the site and post it on here for you, if this helps Link to post Share on other sites
tjsmudger 2 Posted December 10, 2009 Report Share Posted December 10, 2009 http://www.vwaudibreakers.co.uk/breaking-dynamic/index.phpthats the link Link to post Share on other sites
bobveedub 0 Posted December 11, 2009 Author Report Share Posted December 11, 2009 cheers mate! like i said the cover is missing so im probably wise to replace it! if disconnected the fan as a temp measure till i fix it.thanks for your help! Link to post Share on other sites
