whats your idle speed?
my idle is at 500 rpm when warmed up. i've been told this is fine but every other VR^ i've been in idle's higher.
Sounds way too low....
Is it the reading on the Clocks itself' date=' or have you put it on a VAGCOM to show correct reading...?
that is the reading on the clocks mate
Seems like either someone has messed with the clocks before, or it is @ 500rpm.
If you are coming to the NWMeet on the 21st, then Shane, our VAGCOM Diagnoser will be there with machine at hand, so you can see what your VR is idling at.
If you want it checked sooner, he does evening mobile call outs.. £30 a pop.
07956195313
Just found this on youtube comment to the digital rev counter...
I'm not sure what the numbers mean, most of them don't change at all if you're moving or not, but here's the full list:
1) 6214
2) 3
3) 31255
4) 3.0
5) (Test the dashboard LCD)
6) (Counts up one for every 10cm you move the car)
7) (Rev counter)
8) 10.8
