crazy buzzing noise coming from dashboard !!
right guys my vr6 has decided not to work and when i put the keys in the ignition and go to start the car there is this buzzing noise coming from the dash it sounds like under the steering wheel ! when i try to start the car it just turns over and does not even try to fire up, could this be something to do with alarm/immobiliser or a relay fuse ? any help would be amazing as shes my daily driver !
cheers guys
right guys the problem so far.... i have singled out the buzzing to a relay in the fues box ! its got 109 stamped on it does any one know what it does and if i can get it from my local motor parts place or is it going to be a genuine part from VW ??
right i brought a new engine control relay and although the buzzing noise has stopped the car still wont start ! my uncle is a machanic and he said it could possibley be the cam shaft sensor or the crank shaft sensor as they can control the spark is this correct ?!
ive been tinkering about with the pump and im pretty sure that the pump needs replacing cos some times it will pump the fuel through to the injectors and other times it wont ! i will check the relay and fuse tomorrow when theres some sun light !
