Hi guys, started the car earlier and it sounded/felt like it's missing. Now when I took it out earlier it hesitates under load under 2k revs but is fine once above 2k.
Strange as it has been fine but the problem started after I got back to the car from shopping.
Hope it all made sense? lol
if they need replacing VW are around £100 but i think you can get Bosch ones from GSF cheaper?!
Also might want to check the air flow meter, unplug it then plug it back in to see if there is any change in idle, and if its a panel filter take it out and clean it they can get clogged up this time of year!
Car has a decat so won't be that' date=' cheers anyway dude.
Going to check the leads and dizzy cap in the morning. Might replace them while i am at it. Big time pain in the arse
have a quick look in the dark as you'll be able to see any arcing easier
