nickg123 0 Posted December 14, 2004 Report Share Posted December 14, 2004 HELP!My Car is due a service - which is going to be done this week, but i just want to put my mind at rest that it's nothing serious really...........When i got in the car this morning and started it up from Cold, it was really lumpy and idling around 900rpm, it felt like it wasn't firing on all cylinders, if i raised the revs slightly it would go away just above 1k rpm, but driving up the road shortly afterwards it was still doing itI even got a couple of small reasonably quiet pops where it sounds like it's misfiring.Is this likely to be cured simply by replacing the Leads and Plugs? Or am i possibly looking at something more serious?What sort of money is it going to be for new leads and plugs? Link to post Share on other sites
mk3anni 0 Posted December 14, 2004 Report Share Posted December 14, 2004 New plugs are about £2.50 each from GSF. Link to post Share on other sites
VRVIRGIN 0 Posted December 14, 2004 Report Share Posted December 14, 2004 Hope it´s not the coilpack m8, i had that replaced recently, have you seen any small sparks around the engine bay? Link to post Share on other sites
nickg123 0 Posted December 14, 2004 Author Report Share Posted December 14, 2004 I've not looked under the bonnet when it's running - it seems to clear itself so i "hope" it's either Plugs or leads, but then again i guess Coilpack isn't out the question......Is that an expensive item to replace then? Link to post Share on other sites
VRVIRGIN 0 Posted December 14, 2004 Report Share Posted December 14, 2004 Well i had it replaced by a VW dealer over here in spain,and it cost me nearly 450 euros all in. Í´m guessing at around 200 of your hard earned for the coilpack, not sure if u´ll attempt the job yourself or not. I could could easily be wrong though m8. Does it jerk heavily under hard acceleration at times? If u spray a little water around the coilpack and plug ends, just a small amount with a vapouriser, you should start to see if there are sparks. I have a lead end which has a small split in it and it´s really horrible to drive the car with it spiting and spluttering all over the place. Gonna patch it up with some black tape until it goes in for a service. Cars mullered atthe mo, so not such a big deal. Hope this helps m8! Link to post Share on other sites
nickg123 0 Posted December 14, 2004 Author Report Share Posted December 14, 2004 Yeah thanks for the response!I'll get it serviced, and see what the guy thinks - he's an Ex-VW Mechanic, and i've been mates with him for years so i'm sure he'll be honest with meAll being well, new leads/Plugs will hopefully cure it...... certainly can't hurt to replace them as it's on 82k miles and i believe the Plugs/Leads haven't been replaced for a long time! Link to post Share on other sites
VRVIRGIN 0 Posted December 14, 2004 Report Share Posted December 14, 2004 Good luck, let us know how u get on. Link to post Share on other sites
acf8181 0 Posted December 14, 2004 Report Share Posted December 14, 2004 i suspect its just plugs...a friends driver did that when it was (2 years...uhum) overdue its service. after service was A1 again. Link to post Share on other sites
nickg123 0 Posted December 14, 2004 Author Report Share Posted December 14, 2004 I spoke to my mate who's servicing it - he said it's probably the Leads, and as the car's at 82k he suggested replacing them anyway!?!? Link to post Share on other sites
acf8181 0 Posted December 14, 2004 Report Share Posted December 14, 2004 yep, probably a good idea.make sure you specifiy that you want red vw leads, they cost £20 each but are the best. and make sure he doesn't touch them without the special plug removal tool either. Link to post Share on other sites
binliner 0 Posted December 14, 2004 Report Share Posted December 14, 2004 when I spoke to VW about leads they said they only had one set of part numbers and cant order specific colours Link to post Share on other sites
acf8181 0 Posted December 15, 2004 Report Share Posted December 15, 2004 and if vw told you that you could fly would you believe them?! lol Link to post Share on other sites
Eat this 2 Posted December 15, 2004 Report Share Posted December 15, 2004 i wouldnt believe vw if they said they made golfs and polos ps coil packs tend to arch under load ie when u floor it its probably plugs/leads i got mine done at 70k becuase it missed at low revs and now its mint Link to post Share on other sites
Nerih 0 Posted December 15, 2004 Report Share Posted December 15, 2004 mine used to misfire when cold, it was the spark plugs/leads both of them knackered.If it doesnt solve it stick it on vag.com or give it to VW (groan) Link to post Share on other sites
binliner 0 Posted December 15, 2004 Report Share Posted December 15, 2004 and if vw told you that you could fly would you believe them?! lolthe people in the parts place I use are actually very good... but I need to order a new number 1 lead... might save me time sending it back if you've got the part number for the red lead? Link to post Share on other sites
