Off to the scappy, for ABS bits. but what bits do I need?
Hi,
I've had my VR for about 8 months now, and the ABS has never worked. My very freindly MOT man said that someone has taken the warning light bulb out!!
I have toyed with the idea of removing the ABS altogether, which I still might resort to. But my local scap yard has a VR around the same year as mine. I'm thinking that I might as well see if I can fix my ABS with parts from the scappy, but I'm not sure which bits I need?
The ABS pump is at the back of the engine bay. ? And I think it has a ECU of its own. ?
Are they in the same unit? If not where is the ABS ECU?
Any help would be great. Cheers, Max
ps. I nearly forgot...If i do remove the ABS, and fit a bias valve to balance up the front and back brake pressures, how does that work? Do you need a bias valve for each brake (ie 4), or just front and back?
