AJmk2 2 Posted January 19, 2010 Report Share Posted January 19, 2010 I need to find a point i can take a 12v only on when ignition is on from the engine bay. Anyone have any ideas?Also when wiring inside where is a good place to find ignition on power supply ? Thanks to anyone in the know! Link to post Share on other sites
aminder 4 Posted January 19, 2010 Report Share Posted January 19, 2010 Inside best to use direct fusebox linkget a amp meter connect one side to neg, then keep playing with other side to find a power source which clicks on when igition running Link to post Share on other sites
AJmk2 2 Posted January 19, 2010 Author Report Share Posted January 19, 2010 Good idea , would i then just wire into the back of the fuse box ,it looks like on mine there may even be some un used slots. Link to post Share on other sites
CALICO 130 Posted January 19, 2010 Report Share Posted January 19, 2010 check to see if unused points are ign live otherwise wire into the fuse for the radio Link to post Share on other sites
