muttley 0 Posted January 20, 2010 Report Share Posted January 20, 2010 I took a drive to Hatfield last night from Hitchin with is roughly about 15 miles from each other so as usual i used the A1, on the way i noticed that my head lights seemed to be a bit dim but carried on regardless. I turned off at Hatfield (tesco roundabout) and noticed my idle revs were up a little then it started raining. baring in mind i've already got my heaters on, stereo on with amped sub, lights on, and now my wipers. Then it happened everthing all of a sudden stopped stereo went crazy so i turned that off, wipers stopped all lights went off petrol guage went down to zero all heaters stopped and then i just rolled to a stop into the layby. the car was still running but very lumpy and was misssing a lot then it conked out.After i left it 5 mins i started it again as i only needed to get another 50 meters down the road to my mum's house. i revved it a up a bit then all of a sudden everthing came back to life.left it for a while outside my mum's then drove back home to hitchin but i only had my lights on and nothing else, and i got home fine.I'm a bit baffled all i can think of is alternator maybe ???!!!!!??? Link to post Share on other sites
UnitedMotorsport 55 Posted January 20, 2010 Report Share Posted January 20, 2010 Sounds like an alternator fault.Ive seen it before where the alternator doesnt give out a charge unless it goes over a certain RPM. I think my one needed to go over 3k RPM. So if I managed to do a journey not going over that RPM the battery would drain. Link to post Share on other sites
VR6Pete 1,455 Posted January 20, 2010 Report Share Posted January 20, 2010 Had this happen to my 07 plate punto run-about.was driving back from conrwall, after about 200 miles pulled on a service station and battery was flat as a pancake! its been fine since.... I put it down to 'just one of those things' Link to post Share on other sites
thegoth 5 Posted January 20, 2010 Report Share Posted January 20, 2010 does sound like the alternator to me as well. for around a tenner you can get a tester from halfords / maplin / etc to check. alternativle I'm sure a multimeter can be used Link to post Share on other sites
muttley 0 Posted January 20, 2010 Author Report Share Posted January 20, 2010 is it an amp meter that i need to test it ? Link to post Share on other sites
thegoth 5 Posted January 20, 2010 Report Share Posted January 20, 2010 voltage. check the voltage across the battery with the car off and again when running. the alternator should raise it by a good couple of volts. although i may be talking bollox as I use a gadget ;-) Link to post Share on other sites
McPikie 3 Posted January 20, 2010 Report Share Posted January 20, 2010 could be a bad earth, or the charging wire is chaffed? Link to post Share on other sites
AJmk2 2 Posted January 20, 2010 Report Share Posted January 20, 2010 I had this as well on an old car and turned out my alternator belt was slipping. Link to post Share on other sites
