roosevelt1st 1 Posted January 23, 2010 Report Share Posted January 23, 2010 Hi, just checked out the musty smell in the missus' 95 GTi (5 door) tracked it to water in boot. Boot mat has soaked it up good, water in recesses for wire clips on rear edge of boot, maybe coming thru lights??? also wiring loom on passenger side soaked it up and (I think) carried water thru rear seats into base of rear seats,anyone experienced this?can anyone confirm its lights or boot seal have checked rear washer pipe and its dry and not broken/cracked....any ideas appreciated to save an expensive investigation by a garage!cheers Link to post Share on other sites
shail 0 Posted January 23, 2010 Report Share Posted January 23, 2010 I have exactly the same issue. Rear footwell was wet, so thought it may be sunroof leak. But noticed boot carpet wet too. I've had this issue before on a mk3, and I'm nearly certain its the foam seals on the rear lights again. check yours - remove bulb holder from boot, and un bolt the lights and withdraw to inspect seal. Link to post Share on other sites
muttley 0 Posted January 23, 2010 Report Share Posted January 23, 2010 i have this with my Vento as well, the carpet was dripping wet the other night, and i cant figure out where it would have come in Link to post Share on other sites
tjsmudger 2 Posted January 23, 2010 Report Share Posted January 23, 2010 I thought I had a water leak the other week, turns out I had left my half empty/full Camelbak in the boot with the valve unlocked!! Took me an hour checking where this leak had come from!!! Link to post Share on other sites
RAPgolfvr6182 2 Posted January 23, 2010 Report Share Posted January 23, 2010 rear spoiler is the common place for golfs to leak from water drips through the holes that hold the spoiler on Link to post Share on other sites
Rikki 2 Posted January 26, 2010 Report Share Posted January 26, 2010 Rear light seal on a golf. Never heard of leaking through the spoilers??? Link to post Share on other sites
Scott 0 Posted February 8, 2010 Report Share Posted February 8, 2010 I have just put a new tailgate on mine, and came time to swap the number plate.....there were 2 open unplugged holes in the centre of the plate recess, well away from the screws that mounted the plate on, and if I hadnt had the plate off, would never have known they were there, and water would have pissed into the inner door skin then into the inside.......Also the hinges may not be adjusted to give a tight seal around the door. Link to post Share on other sites
