Pipe come unstuck in engine bay, not sure what it is for, help needed pics provided.
you can get them from ford also as galaxy had vr6 lump fitted , worth checking if ford are cheaper
The Ford part number 7364573
from vw for a golf you need the whole pipe from air mass meter to throttle body!
part number is 3A0 129 615D at £121.65 or a sharan VR6 -
the number for the sharan one is 7M0 128 101 at a much better price of £26.59......
all are same part in bag
you can get them from ford also as galaxy had vr6 lump fitted ' date=' worth checking if ford are cheaper
Thanks for the advice.
So I guess it is a case of ordering the Sharan one, giving it to my mechanic and praying it doesn't cost the earth to fit? Is it definitely the right one? How come VW charge so much more for the same part?
Also, being in the state it is currently in, what detrimental effect is it having on perforamce, or anything?
MAny thanks
Mike
it's a DIYer. by the looks of yours two jubilee clips and a nasty spring clip. best be prepared to replace the spring clip with a small jubilee as they are never the same one they've been removed.
the mk3 part comes complete with the corrugated intake pipe it attaches to.
the worst that will happen is that it could allow a small amount of unmetered / unfiltered air in. But is more likely just to leak oily air out. So no more than a bit of a smell.
