haldex ecu location ???
hi there i got a golf 00 vr6 4motion and i was having problem with rear drive so i got a appoinment at the dealership and they told me that the haldex ecu was fried an i needit a new one. only problem is that the ecu cost an arm and a leg in the dealership, so i want to know where the ecu is locadet and if i can use ecu from any mk4 4motion from a scrapyard ???
Its next to the diff filter, remove the plugs from the ECU, remove the beam bolt thats near it as this will give you a bit more room to get it out, and then unbolt the ECU and with a little wiggling of the unit it should come out.
I googled this and got this information from an Audi forum. You can fit a performance ECU which I'm guessing will be loads cheaper than the oem one and give you some fun too.
