terrorste 0 Posted February 6, 2010 Report Share Posted February 6, 2010 What is this black plastic pipe? i have water leaking from behind this onto the oil cooler any one got any clues on what it could be and prices to fix ect? Link to post Share on other sites
ingham 5 Posted February 6, 2010 Report Share Posted February 6, 2010 the rubber pipe going to oil cooler is prone to fail ,mine did ..beware the plastic pipe is very brittle where it meets the rubber pipe when old and will prob snap so be prepared to replace it also, its nick named crack pipe on here Link to post Share on other sites
terrorste 0 Posted February 6, 2010 Author Report Share Posted February 6, 2010 Ah yes the famous crack pipe! is it expensive to replace? Link to post Share on other sites
ingham 5 Posted February 6, 2010 Report Share Posted February 6, 2010 http://www.vr6oc.com/e107_plugins/forum/forum_viewtopic.php?241841.post Link to post Share on other sites
terrorste 0 Posted February 6, 2010 Author Report Share Posted February 6, 2010 Ah nice one cheers for that i just wonder how much the labor will cost to fix it kinda make me wish i knew what i was doing. Link to post Share on other sites
terrorste 0 Posted February 7, 2010 Author Report Share Posted February 7, 2010 So does the crack pipe just hold coolant? just had a text off a mate saying his mate will replace it for 200 all in is that a good price? Link to post Share on other sites
Ben Seabrook 4 Posted February 7, 2010 Report Share Posted February 7, 2010 yeah it just holds coolant and that sounds way too much to me mate - I am not mechanically minded at all but I managed to change mine fine, took me about an hour all in ! Link to post Share on other sites
Ben Seabrook 4 Posted February 7, 2010 Report Share Posted February 7, 2010 I just put a guide to removing the thermostat housing in the engine section of the knowldege vault Link to post Share on other sites
terrorste 0 Posted February 7, 2010 Author Report Share Posted February 7, 2010 So its not a front end job off then? Link to post Share on other sites
vr6stormt 0 Posted February 7, 2010 Report Share Posted February 7, 2010 i would charge you about £30 to do thermo and c/pipe that quote is way out there i did mine without front off just be carefull Link to post Share on other sites
Ben Seabrook 4 Posted February 7, 2010 Report Share Posted February 7, 2010 So its not a front end job off then?no mate just remove the coilpack to make it easier and your away Link to post Share on other sites
terrorste 0 Posted February 7, 2010 Author Report Share Posted February 7, 2010 i'd love to try it myself but without the tools and knowlage i'm screwed unless I find an honest person lol Link to post Share on other sites
terrorste 0 Posted February 7, 2010 Author Report Share Posted February 7, 2010 I might just give this a go myself but if i mess up i'm stuck Link to post Share on other sites
Ben Seabrook 4 Posted February 7, 2010 Report Share Posted February 7, 2010 could always use the locate member search http://www.vr6oc.com/userlocate.php to find members in your area mate and see if one would be willing to help you out Link to post Share on other sites
terrorste 0 Posted February 7, 2010 Author Report Share Posted February 7, 2010 I have had a buchers and looks like no active members on here that fix stuff. its a shame we dont have mechanic helps sticky as well as a vag com one. Idea maybe ? Link to post Share on other sites
Ben Seabrook 4 Posted February 7, 2010 Report Share Posted February 7, 2010 that's not a bad idea mate the nearest guy I know who would do it is dlea but he is a couple of hours drive away Link to post Share on other sites
terrorste 0 Posted February 7, 2010 Author Report Share Posted February 7, 2010 Yea its a shame we dont have a section of people offering help mechanically to other VR owners. good opertunity to lean about our cars too! Link to post Share on other sites
craggsy 91 Posted February 7, 2010 Report Share Posted February 7, 2010 Can get tricky tho as it might come across as we are reccomending them and can get the club into all sorts of bother.So just recommedations from people will have to surfice. As Ben says Dave Lea is in cheshire so a couple of hours drive. Well respected on here Link to post Share on other sites
GraLaw 0 Posted February 8, 2010 Report Share Posted February 8, 2010 Just done mine. Took me half an hour. All you need is an allen key for two bolts and mould grips to get the clip off the small hose. It just pulls off then. Pushing the new one in the water pump end can be a sod, I had trouble at first but I noticed slight rusting around the lip and sprayed it with wd40. Went straight in. Link to post Share on other sites
Gooseman 0 Posted March 18, 2010 Report Share Posted March 18, 2010 way easyer to take front of make sure to change both rubber pipes going to and from oil cooler 40 min Link to post Share on other sites
