colwan 0 Posted February 15, 2010 Report Share Posted February 15, 2010 Just about done my raddo 1990 vr6 conversion only snag is the temp gauge isn’t working!! It maddening! I’ve done the d2 to e8 link and put a live to the fuel gauge to get that to work but no temp!!! it's not circulating the water to the heater matrix very well either Must be the thermostat so iv got to take it apart any way so new bloody sender as well but I don’t think that’s why I’m not getting temp reading as its not even moving when I connect a live to the yellow and red wire on the dash loom!! It’s driving me mad!! I want to put the fuse box away i'm sick of looking at it arrg!!!:@ Link to post Share on other sites
J5KE F 0 Posted February 15, 2010 Report Share Posted February 15, 2010 Have u tried a different set of clocks?? Did u know if the ones u have worked before?? Most likely wiring, plug or stat.. The old process of elimination is the only way ahead mate! Link to post Share on other sites
colwan 0 Posted February 16, 2010 Author Report Share Posted February 16, 2010 Tell me about it! got 3 sets of clocks so i'll go test them now will post answer Link to post Share on other sites
colwan 0 Posted February 16, 2010 Author Report Share Posted February 16, 2010 Well still no joy! and i'v discoverd that the fuel gauge works fine untill you start it then it go's up by 1/5th humm???? has anybody elce had this problem with vr conversions? Link to post Share on other sites
colwan 0 Posted February 22, 2010 Author Report Share Posted February 22, 2010 Well slight update i'v sorted the temp gague, it had come off the pin inside so i'v wired it to the yellow and red on G2/3 only problem is when the ign is on it sky rockets up unless you start the engine?? also now when i connect the fuel gague it drops them both down to a false reading!! Link to post Share on other sites
spindat45 0 Posted February 22, 2010 Report Share Posted February 22, 2010 Send Sparkz a PM. He might be able to help.Kevin Link to post Share on other sites
colwan 0 Posted February 25, 2010 Author Report Share Posted February 25, 2010 Right well, sorted the temp gauge out by putting a relay on it from an engine running live. Unfortunately the fuel gauge is still buggered! Guess I’ll just have to put a gallon in the boot!! Link to post Share on other sites
