Lukey. 381 Posted April 28, 2013 Author Report Share Posted April 28, 2013 You got some big improvements on yours.Got the cleaned up gearbox back on today, only took 2 hours lolThen filled it up with fresh gear oil, went for MT90 this time over MTL as the MTL after 3 years had started to feel a bit "thin"Redline by name.... Link to post Share on other sites
VR6Pete 1,455 Posted April 28, 2013 Report Share Posted April 28, 2013 I've got the redline stuff in mine, not cheap but highly rated! Link to post Share on other sites
Lukey. 381 Posted April 28, 2013 Author Report Share Posted April 28, 2013 Wasn't so bad opie had a 25% off deal. Link to post Share on other sites
VR6Pete 1,455 Posted April 28, 2013 Report Share Posted April 28, 2013 Cooool. We also have a discount code for club members when there isn't a deal on Link to post Share on other sites
Lukey. 381 Posted April 29, 2013 Author Report Share Posted April 29, 2013 I now have colour coded injectorsAnd have put a fair few parts back on the car, also painted the oil filter housing too as it looked so dirty against the rest of the fresh silver Link to post Share on other sites
Woodyman84 3 Posted April 29, 2013 Report Share Posted April 29, 2013 The little.bits.make all difference :-) Link to post Share on other sites
Lukey. 381 Posted April 30, 2013 Author Report Share Posted April 30, 2013 Replaced all the rusted cam cover bolts with these much smarter stainless socket cap bolts, I replaced the cam cover gasket too, no wonder the old one seeped oil, it had hardened so much it shattered when I pried it off! Link to post Share on other sites
Woodyman84 3 Posted April 30, 2013 Report Share Posted April 30, 2013 Looking good. I need to do rocker gasket, I just worry about taking inlet off an disturbing my crusty wiring and ht leads lol Link to post Share on other sites
Lukey. 381 Posted May 2, 2013 Author Report Share Posted May 2, 2013 Got a fair bit back on last night, I repainted the upper and lower inlets too, nice and fresh. Link to post Share on other sites
VIW28 29 Posted May 2, 2013 Report Share Posted May 2, 2013 Looks brilliant mate! Link to post Share on other sites
Woodyman84 3 Posted May 2, 2013 Report Share Posted May 2, 2013 loving the black an red! Link to post Share on other sites
Lukey. 381 Posted May 2, 2013 Author Report Share Posted May 2, 2013 I'm pleased with how the plastic can cover and HT lead runners came up, I used wet'n black aerosol tyre gel on them and left them to soak it up overnight then buffed the excess off. They look awesome now. Link to post Share on other sites
Lukey. 381 Posted May 4, 2013 Author Report Share Posted May 4, 2013 Replaced the steering boots and track rod ends last nightThese were a pain in the arse to get off and this is pretty much how they were on the car, they are so well hidden I never noticed before.And these were even more of a pain in the arse to get on, I cleaned up any old moly grease and dust off the rack and ball sockets and thinly applied some fresh moly grease I managed to twist the track rod ends off and the lock nut stayed exactly where it was, so hopefully the tracking wont be out Link to post Share on other sites
Lukey. 381 Posted May 4, 2013 Author Report Share Posted May 4, 2013 Good news, everything still works! Got it started and everything was good, ran it up till the fans kicked on and t-stat opened then topped up the coolant again. The engine sounded silky smooth, I didn't think it sounded chainy before even with what I found to be totally smashed guides, but you can't hear anything of them at all now. I had a single oil drip coming down the little tin gearbox end plate next to the sump, I torqued them up to spec when refitted but tightened up the sump bolts along the chain cover plate a but more and after a 10 mile drive no longer leaks. Also on the drive out the v-belt splash shield decided to snap its posts off and throw itself on the road, picked it up intact though so will have to install a couple of new threaded posts to get it back on. I'm getting some clutch judder only when engaging the clutch, in neutral and when fully engaged its fine, only when setting off or holding on the clutch, so putting this down to the brand new clutch as even on the drive across town it improved. So hopefully in 100 or so miles it'll be much nicer. Link to post Share on other sites
VR6Pete 1,455 Posted May 4, 2013 Report Share Posted May 4, 2013 Great result mate no excuse for not coming events now You always get teething issues, but sounds like your working them out Link to post Share on other sites
Daverse 175 Posted May 4, 2013 Report Share Posted May 4, 2013 It's not a VR I know, but i remember when i had my clutch done on my citroen, it juddered a bit, and for the first 100 miles or so the clutch was almost like a paddle clutch, either on or off. So hopefully yours will burn in fine Link to post Share on other sites
Therusterman 59 Posted May 5, 2013 Report Share Posted May 5, 2013 Nice work Luke, bet your really happy with your work! Is the car your daily driver or did you book time off work and get it all done in the week? Link to post Share on other sites
Lukey. 381 Posted May 5, 2013 Author Report Share Posted May 5, 2013 It's taken me about 2 weeks from start to finish doing it when I could, late nights, weekends etc, but I was prob more picky than your average person, like everything was filthy and I spent a whole day just cleaning and another day painting the various parts. We had the A3 so could get about but took more planning and one person had to go collect the other etc. I've had to do the job sooner than I wanted to as I have to not just have a wrist surgery but now have an exploratory surgery before to decide which operation would be best then have it a few weeks after so wanted the car to be in good working order so I didn't have to fix it later on. Link to post Share on other sites
Lukey. 381 Posted May 11, 2013 Author Report Share Posted May 11, 2013 Got the brand new genuine flywheel on hopefully will solve the vibration. Link to post Share on other sites
VR6Pete 1,455 Posted May 11, 2013 Report Share Posted May 11, 2013 nice! how much was that for a fly wheel? Link to post Share on other sites
Lukey. 381 Posted May 11, 2013 Author Report Share Posted May 11, 2013 I think its about £87 on an exchange basis or about £150 outright from TPS, I'll find out when I take my old one in. I didn't even ask my dealer. I thought this was a pretty good price for a genuine one but they are only solid so not complex to make. If not I was going to go for a sachs one for only £55 shipped but had to get it from USA. Link to post Share on other sites
Lukey. 381 Posted May 13, 2013 Author Report Share Posted May 13, 2013 The new flywheel has done the trick, no more shuddering along The stupid mounting posts for the splash shield and undertray had all snapped off when I undid the nuts to take everything off, so I ground them flat and drilled and tapped some holes and blathered them in underseal for protection, they can be bolted on much more securely now.Driver sideGearbox side Link to post Share on other sites
VR6Pete 1,455 Posted May 13, 2013 Report Share Posted May 13, 2013 Excellent news there mate! Result! Onwards and upwards now. Link to post Share on other sites
Lukey. 381 Posted May 13, 2013 Author Report Share Posted May 13, 2013 Cheers mate I'm super glad its now right, I didn't want it hanging over me after surgery and not being able to fix it. Link to post Share on other sites
Lukey. 381 Posted June 3, 2013 Author Report Share Posted June 3, 2013 Got the car SORN'd, washed, waxed and covered now, not too sure how long for at the moment, depends on what needs doing. Link to post Share on other sites
