bungy 2 Posted July 8, 2010 Author Report Share Posted July 8, 2010 I'll ask next time i'm in TPS. Link to post Share on other sites
bungy 2 Posted February 20, 2011 Author Report Share Posted February 20, 2011 Updated, please keep part numbers coming as and when you get spares.... Link to post Share on other sites
bungy 2 Posted March 9, 2011 Author Report Share Posted March 9, 2011 Reminder for more part numbers please. Link to post Share on other sites
d1cky1982 0 Posted December 29, 2013 Report Share Posted December 29, 2013 Any updates to this ? Link to post Share on other sites
HOTSHOT III 2 Posted June 19, 2016 Report Share Posted June 19, 2016 (edited) Excellent thread, i'm looking at buying a 4Mo and this has been very useful One thing worth mentioning though, you should never mix DOT 4 and DOT 5 fluid due to DOT 5 being silicone based. According to Wikipedia: DOT 5 is one of several North American designations of automotive hydraulic brake fluid, denoting a particular mixture of chemicals imparting specified ranges of boiling point. DOT 5 is a silicone-based brake fluid (contains at least 70% by weight of a diorgano polysiloxane[1]). Unlike polyethylene glycol based fluids, Dot 5 is hydrophobic.[2] An advantage over other forms of brake fluid is that silicone has a more stable viscosity index over a wider temperature range. Another property is that it does not damage paint.[citation needed] Using DOT 5 in a DOT 3 or DOT 4 system without proper flushing will cause damage to the seals and cause brake failure.[citation needed] DOT 5 brake fluid is not compatible with anti-lock brake systems. DOT 5 brake fluid absorbs a small amount of air requiring care when bleeding the system of air.[citation needed] Boiling points[edit] Minimal boiling points for these specifications are as follows (wet boiling point defined as 3.7% water by volume): Boiling point ranges [3] Dry boiling point Wet boiling point DOT 3 205 °C (401 °F) 140 °C (284 °F) DOT 4 230 °C (446 °F) 155 °C (311 °F) DOT 5 260 °C (500 °F) 180 °C (356 °F) DOT 5.1 260 °C (500 °F) 180 °C (356 °F) Edited June 19, 2016 by HOTSHOT III Bealieboy 1 Link to post Share on other sites
