VRTDan 0 Posted March 8, 2010 Report Share Posted March 8, 2010 Cruising along at just over 30mph & as I came to a junction the car starts to chug. Feels under powered, sounds like a timing issue. It's not running on all cylinders, other than plugs or leads, what could cause this? I've had a look under the bonnet & I cant see anything obvious (tho it is dark outside)My mate might be able to pop over with his VAG COM, but that might not be till the weekend.Any suggestions? Thanks Link to post Share on other sites
Ben Seabrook 4 Posted March 8, 2010 Report Share Posted March 8, 2010 if it's when the clutch is pressed in I would say ISV or throttle position sensor mate or MAF needs a clean - had to do that quite a lot with my charged VR (due to position of the air filter I think and the roads I am forced to drive down! ) Link to post Share on other sites
craggsy 91 Posted March 8, 2010 Report Share Posted March 8, 2010 Have you aqctually checked condition of plugs and leads? Link to post Share on other sites
VRTDan 0 Posted March 8, 2010 Author Report Share Posted March 8, 2010 I went like it half hour ago and it's pitch black outside. I have literally been round the engine bay with a torch making sure nothing has come loose or I have no leaks anywhere. I cant do anything till tomorrow night now.Normally if it ever ran rough, the hose had started to come off the intake of the charger,so I'd just put it back on & it would be back to normal, but the hose is looked fine.Maybe the MAF could be a bit coked up, I didn't really give it the usual clear out on the way home?? Link to post Share on other sites
Ben Seabrook 4 Posted March 8, 2010 Report Share Posted March 8, 2010 yeah best bet then mate is to wait until daylight and then have a good look first for anything obvious Link to post Share on other sites
VRTDan 0 Posted March 8, 2010 Author Report Share Posted March 8, 2010 What do you thinks best to clean the MAF up with? A bit of carb cleaner? Link to post Share on other sites
Ben Seabrook 4 Posted March 8, 2010 Report Share Posted March 8, 2010 no mate you need electrical contact cleaner or proper MAF cleaner can get the electrical contact cleaner from Halfords or maplins places like that Link to post Share on other sites
cabrioman 6 Posted March 8, 2010 Report Share Posted March 8, 2010 i had silimar fault was my lambda foo barred .... does it stall ??? Link to post Share on other sites
J5KE F 0 Posted March 8, 2010 Report Share Posted March 8, 2010 Does sound like maf to me.. Check connections too! Link to post Share on other sites
Rikki 2 Posted March 8, 2010 Report Share Posted March 8, 2010 Why do people advise on here to clean mafs with carb cleaber....this can make it worse. Use ispropyl alcohol only as it leaves no residue Link to post Share on other sites
Ben Seabrook 4 Posted March 8, 2010 Report Share Posted March 8, 2010 Rikki not seen anyone recommend cleaning it with carb cleaner mate ?? I said not too !! Link to post Share on other sites
CALICO 130 Posted March 8, 2010 Report Share Posted March 8, 2010 some one mentioned using on another thread a couple of days ago DOH! Link to post Share on other sites
VRTDan 0 Posted March 8, 2010 Author Report Share Posted March 8, 2010 I asked if I should use it not told myself to lol!Where do you get ispropyl ? Not heard of it before? Link to post Share on other sites
Ben Seabrook 4 Posted March 8, 2010 Report Share Posted March 8, 2010 again you can get isopropyl from maplins or a similar electrics place Link to post Share on other sites
Rikki 2 Posted March 8, 2010 Report Share Posted March 8, 2010 Yup deffo maplins....got some to do mine. Wasnt havin a pop at anyone directly there! sorry if it came across like that. But when you switch iff your car the maf heats a wire to over 1000 deg'c, which is thinner than a human hair, to burn off all the s**t! Carb cleaner could screw it completley Link to post Share on other sites
VRTDan 0 Posted March 9, 2010 Author Report Share Posted March 9, 2010 LOL no worries mate. Fingers crossed that's all it is. I'll get some at lunch time & will look at this one tonight.Cheers Link to post Share on other sites
Ben Seabrook 4 Posted March 9, 2010 Report Share Posted March 9, 2010 No worries Rikki as said either get the isopropyl or electrical contact cleaner and you will be fine.Let us know how you get on matey and good luck. Link to post Share on other sites
VRTDan 0 Posted March 9, 2010 Author Report Share Posted March 9, 2010 The next department to me at work builds PCB circuit boards etc. I’ve had a word with them & said what I had been advised to use by you guys. They said they use something called Fluxclene, which will do the same job & leave no residue, which they can give me a can of. Link to post Share on other sites
VRTDan 0 Posted March 9, 2010 Author Report Share Posted March 9, 2010 Strange, came home @ lunch time, started the car.... & all is ok? Link to post Share on other sites
AJmk2 2 Posted March 9, 2010 Report Share Posted March 9, 2010 If its missfiring on 2 cylinders could be your coilpack. Mine would missfire all the time and sound horrible and then would just run fine for a while and go bad again. Link to post Share on other sites
VRTDan 0 Posted March 9, 2010 Author Report Share Posted March 9, 2010 If it was that, would it still show the fault when I plug the VAG COM in? Link to post Share on other sites
ginga_d 0 Posted March 9, 2010 Report Share Posted March 9, 2010 i have just been reading through this and i have exacly th same prob at the mo but with back fire Link to post Share on other sites
VRTDan 0 Posted March 9, 2010 Author Report Share Posted March 9, 2010 Getting a price on a new coil pack then lol Link to post Share on other sites
Ben Seabrook 4 Posted March 9, 2010 Report Share Posted March 9, 2010 if it's the coilpack go out tonight when its dark start it and then look all around the coilpack for any signs of arcing - you can also take it off and check it for any cracks etc and they are easy to fix with epoxy glue mate Link to post Share on other sites
Rikki 2 Posted March 9, 2010 Report Share Posted March 9, 2010 Spray some water on it too and see if theres any arcing or if the car runs worse Link to post Share on other sites
