golf harris 0 Posted March 12, 2010 Report Share Posted March 12, 2010 i thought that obd1 (body kit) obd2(colour coded) but they say you learn something new every day!!! get that misty bottle out mate and give that coilpack a quick 'mist' Link to post Share on other sites
b19drg 0 Posted March 13, 2010 Report Share Posted March 13, 2010 Ok so I have got a really bad miss fire on mine tonight , been outside with the water bottle and its arcing pretty good , how do i seal it up a little mini guide would be great and what stuff do i need to seal it with also , are they easy to get off ?? help please !! Link to post Share on other sites
Ben Seabrook 4 Posted March 13, 2010 Report Share Posted March 13, 2010 Dan mate if you mean your coilpacl, then it's easy remove it from the car get some plastic epoxy two part glue. Have a good look all over it for any cracks and then cover them in the glue It's worse if you look and cant see any cracks as that means its broken down inside one of the coils which you cant fix Link to post Share on other sites
b19drg 0 Posted March 13, 2010 Report Share Posted March 13, 2010 Nice one , thanks mate , it's going in for it's full service on Monday but hope I don't have to spend out on a new coil pack but my leads are arcing over the plugs as well so Lots of parts ordered today ! Glad it's happened now and not in Germany ! See ya soon mate Link to post Share on other sites
ginga_d 0 Posted March 13, 2010 Report Share Posted March 13, 2010 sorry for cuttin in here but mine is runnin Shite but only when he is warmed up to runnin temp. then not firing on all cylinders. tried the spraying no sparks,all leads are fitted nothing loose. do i just buy a coilpack and hope that's it or could there be anything else? Link to post Share on other sites
Ben Seabrook 4 Posted March 13, 2010 Report Share Posted March 13, 2010 bowser I know you can't always tell but your best bet is to take the coilpack off and have a look at it to see if there are any cracks at all first Link to post Share on other sites
thegoth 5 Posted March 13, 2010 Report Share Posted March 13, 2010 Has it been on vag com mate? Link to post Share on other sites
ginga_d 0 Posted March 13, 2010 Report Share Posted March 13, 2010 has been plugged in and i have a temp sensor fault also. but i will take the coilpack off and have a look too Link to post Share on other sites
matty.vrt 120 Posted March 13, 2010 Report Share Posted March 13, 2010 leave your car running and pull of your ht leads one at a time and the one that you pull of that dosent change the engine note is the problem lead or plug.works for me Link to post Share on other sites
ginga_d 0 Posted March 13, 2010 Report Share Posted March 13, 2010 mmm haven't thought of that. losing my call with it at the mo wanted to beat it this mornin! Link to post Share on other sites
thegoth 5 Posted March 13, 2010 Report Share Posted March 13, 2010 has been plugged in and i have a temp sensor fault also. but i will take the coilpack off and have a look tooI thought temp sensor wheh I read the symptoms. If the ECU isn't seeing the engine get hot it will be over fuelling Link to post Share on other sites
craggsy 91 Posted March 13, 2010 Report Share Posted March 13, 2010 Yep temp sensor(blue one) will make it run crap also.Unplug blue temp sensor to se if it runs the same Link to post Share on other sites
ginga_d 0 Posted March 14, 2010 Report Share Posted March 14, 2010 started it this morn got him up to coughing heat and unplugged the blue one. started to rev higher but he wasn't chugging at all. marvelous! Link to post Share on other sites
VRTDan 0 Posted March 14, 2010 Author Report Share Posted March 14, 2010 Quick update guys - Replaced the coil pack with a GSF one, problem solved. Car feels sooooo much better too. Must have been going for some time! Thanks for your help!! Link to post Share on other sites
gary.scales 0 Posted March 14, 2010 Report Share Posted March 14, 2010 VRTDan, how much was it mate and where from? Need one also :-) Link to post Share on other sites
Rikki 2 Posted March 14, 2010 Report Share Posted March 14, 2010 err i would guess he got it from GSF as its a GSF one!!!!!!!!!! Web says 118.00 + vat. Link to post Share on other sites
craggsy 91 Posted March 14, 2010 Report Share Posted March 14, 2010 Yep thats what i paid for mine from GSF Link to post Share on other sites
VRTDan 0 Posted March 14, 2010 Author Report Share Posted March 14, 2010 lol yesh GSF. They only had the cheaper on in stock, so had to buy it. £78.00 & worth every penny. Glad to have the car back to normal! Link to post Share on other sites
b19drg 0 Posted March 15, 2010 Report Share Posted March 15, 2010 Miss fire sorted , compression test on number 6 down to 50 then re tried again and is now 140 ish consistent , plug was all burnt and knackered , replaced plugs and all good ! hope there was no underlying fault there but shes running good now all the rest of the bits to sort out !! Link to post Share on other sites
ginga_d 0 Posted March 16, 2010 Report Share Posted March 16, 2010 ok so this morn i have changed the blue temp sensor. runnin very slightly better but still sounds like a tractor! Link to post Share on other sites
