VRTDan 0 Posted March 9, 2010 Author Report Share Posted March 9, 2010 Water on potential live/open electrics? Link to post Share on other sites
spadam 7 Posted March 9, 2010 Report Share Posted March 9, 2010 He means a very fine mist of water from something like a spray bottle to see if the coilpack is arcing. Just dont spray with hose/ pressure washer lol Link to post Share on other sites
Ben Seabrook 4 Posted March 9, 2010 Report Share Posted March 9, 2010 as above from a misting bottle not the hose mate will be fine spray it above the coil and let it fall gently over it Link to post Share on other sites
VRTDan 0 Posted March 9, 2010 Author Report Share Posted March 9, 2010 LOL can you imagine. I should have an empty squirty bottle kicking about. I'll give a go Link to post Share on other sites
AJmk2 2 Posted March 9, 2010 Report Share Posted March 9, 2010 Yea , when mine had gone i could see some arking at night. Definatly need to shop around though as prices on the packs vary a lot! Link to post Share on other sites
VRTDan 0 Posted March 9, 2010 Author Report Share Posted March 9, 2010 Trade Parts Centre, with Trade Discount - £155.10!! £235 without!! OUCH!. I think I'll be shopping about! Link to post Share on other sites
Ben Seabrook 4 Posted March 9, 2010 Report Share Posted March 9, 2010 well check yours first mate and if there is a small crack in it you can always just epoxy it up and that lasts for ages Link to post Share on other sites
craggsy 91 Posted March 9, 2010 Report Share Posted March 9, 2010 I bought mine from GSF.....genuine BERU one for less than a ton if i remember correctly. Would have to dig receipt out to confirm that Link to post Share on other sites
MJ Vr6 79 Posted March 9, 2010 Report Share Posted March 9, 2010 Coil pack does'nt always neccesary show arckin when farcked, neither cracks, Some of them can just go...!Check your HT leads as well, as the kinks, heat, can cause missfire too, as seen on a few of the members cars on here...Not mentioning no names..LoL!! (Wedgy, cough cough Widgy, ooops Squidgy!)Oh Yeah... SLCharged-Remember Blue Coconut! LoL! Link to post Share on other sites
MJ Vr6 79 Posted March 9, 2010 Report Share Posted March 9, 2010 PS- If your Coil Pack is busted, it does not show up on VAGCOM. Link to post Share on other sites
VRTDan 0 Posted March 10, 2010 Author Report Share Posted March 10, 2010 Looked at the car last night. I couldn't see any cracking, or arcking? It was again running fine??I'll probably not get to drive it now till Friday/Saturday, so won't know anymore till then. Link to post Share on other sites
Antihero1981 8 Posted March 11, 2010 Report Share Posted March 11, 2010 what about spark plugs? Link to post Share on other sites
golf harris 0 Posted March 11, 2010 Report Share Posted March 11, 2010 this happend to my missus 97 vr6, running fine one minute then firing on 3/4 cylinders and that was the coil pack had a hair line crack running across it hardly even noticeable really, changed it for a ford galaxy vr6 coilpack and all sweet after that.i also agree with what ,MJ vr6, said in his post that they can just call last orders and die with no visual signs!! get a second hand ford galaxy vr6 one to try as for some reason there a lot cheaper (but identical parts ,even has the vag stamp on it) than a second hand golf vr6 one, Link to post Share on other sites
gary.scales 0 Posted March 11, 2010 Report Share Posted March 11, 2010 aha! does this explain whilst sometimes, (and can, but not always) drive rough in the wet, and can feel like its running on 4 when it is howling down on a motorway run??!! Also had 3 sets of HT leads, all different makes, and all pop off certain spark plugs.... has this thread solved all my running rough sometimes problems!! Where's that torch and spray mist bottle!!! Link to post Share on other sites
golf harris 0 Posted March 11, 2010 Report Share Posted March 11, 2010 quite possible that you have a crack in your coil pack and moisture getting in causing missfires,but looking at your profile photo you have the older obd 1 model with a dizzy cap,think im right anyway... unless some of the bodykitted older ones had coilpacks too??? Link to post Share on other sites
gary.scales 0 Posted March 11, 2010 Report Share Posted March 11, 2010 how can you tell it's an obd1 from the back!! hmm, not a clue.... sorry, cheers though!! Link to post Share on other sites
golf harris 0 Posted March 11, 2010 Report Share Posted March 11, 2010 the body kit is the giverway and the non colour coded door rubs, think as a rule obd1 cars has these and the newer ,n reg on i think ( obd2 cars ) deleted the body kit and had colour coded door rubs plus other parts ie,coil pack, better throttle body....but your car from what i know probably has a dizzy cap so i would check that out as that will cause missfires also if its old and all the contacts have worn away,check it out!! Link to post Share on other sites
gary.scales 0 Posted March 11, 2010 Report Share Posted March 11, 2010 wicked, cheers!! Link to post Share on other sites
AJmk2 2 Posted March 11, 2010 Report Share Posted March 11, 2010 Yea sounds like your problem mine did same exact thing. As soon as it got hot enough and dryed out id be running on 6 again but not a good thing for engine. Link to post Share on other sites
gary.scales 0 Posted March 11, 2010 Report Share Posted March 11, 2010 cheers AJ, if your in oxford again and need that ht lead pushy down thing, let me know!! Time for a new part me thinks, nurburgring not far away.... Link to post Share on other sites
Rikki 2 Posted March 11, 2010 Report Share Posted March 11, 2010 the body kit is the giverway and the non colour coded door rubs' date=' think as a rule obd1 cars has these and the newer ,n reg on i think ( obd2 cars ) deleted the body kit and had colour coded door rubs plus other parts ie,coil pack, better throttle body....but your car from what i know probably has a dizzy cap so i would check that out as that will cause missfires also if its old and all the contacts have worn away,check it out!![/quote']no there are obd1 cars with full colour coding and dizzy models are early 92/93 not "the ones with arches" as everyone thinks. Link to post Share on other sites
gary.scales 0 Posted March 11, 2010 Report Share Posted March 11, 2010 too confusing now, do i need a dizzy or a coil pack, where do I start looking?? :-) Link to post Share on other sites
Ben Seabrook 4 Posted March 11, 2010 Report Share Posted March 11, 2010 what year is your car Gary ? Link to post Share on other sites
gary.scales 0 Posted March 12, 2010 Report Share Posted March 12, 2010 april 95 Ben Link to post Share on other sites
gary.scales 0 Posted March 12, 2010 Report Share Posted March 12, 2010 saw on the other forum, its a rectangle one, time for the misty spray bottle...... Link to post Share on other sites
