Spadam's vr6 build thread (For Sale)
  • Replies 252
  • Created
  • Last Reply
Top Posters In This Topic
  • 3 weeks later...
  • 1 month later...
  • 5 weeks later...
Sounds good m8 how does that work then. May well need a hand if anyone is around when i get the bushes. As think i need to take whole rear beam off to change bushes. Im also on the look out for some oem wishbones so i can spray them and build them up with new bushes and ball joints etc.
Right failed MOT today only a new number plate bulb needed and 2 rear wheel bearings. The tester said that bearings seemed fine and there was no noise just exsessive play. So suggested i just tighten then up a bit. Can this be done. Im getting new bulbs in the week for a re test on thursday. Can the rear wheel bearings just be tightened up then as i will do that 1 night this week.
nice one mate nice easy test for you i'm sure they can be tighend up never known any that can't be (not to say there isn't any out there)
normaly just take the cap off that covers them then there is a castle nut with split pin through them just take out pin tighten up nut a bit and replace pin and bobs your uncle
Well i tightened wheel bearings tonight so going for a retest tomorow if they can fit me in. All being good it should pass. Next up is to pay Neal for a spare set of wishbones which i will spray and build up with polybushes and new ball joints.
