oil coolers (track car)
Setrab 16 row slim line cooler with mocal thermostatic sandwich plate. The Phirm got all the components together for me. Biggest bonus is scrapping the water/oil heat exchanger so the coolant isn't heating the oil and vice versa. Had it positioned behind the small bumper vent, passenger side and covered the front face with ally sheet so it worked like a heat sink, then if I needed the extra cooling for play time, undid 2 bolts and slid the sheild off.
I used a 16 row thermostat controlled one when I went SC and it was spot on' date=' you could sit in traffic for an hour on a boiling day and it would just reach 98, ring it's neck an it would occasionally reach 102
Marc which one did you use mate ?
I'm really worried about mine at the moment, since fitting port and polished head it's running at 114 degrees on a run and pretty much 100 general use. Is it worth fitting a better cooler
Setrab 16 row slim line cooler with mocal thermostatic sandwich plate. The Phirm got all the components together for me. Biggest bonus is scrapping the water/oil heat exchanger so the coolant isn't heating the oil and vice versa. Had it positioned behind the small bumper vent' date=' passenger side and covered the front face with ally sheet so it worked like a heat sink, then if I needed the extra cooling for play time, undid 2 bolts and slid the sheild off.
lovely thanks very much for the info matey :) vince recommended I fit one gary and if your temps are high I can only see it as a good addition mate either that or buy tony's water injection kit !!
when was your last oil change? I found fresh oil made a fairly big difference in temps, but an oil cooler is worth doing on any VR if only just to bin the heat exchanger as they are a weak link
Last oil change was a week ago, semi synthetic
I've been running a cooler on mine for a while without the standard water cooler and I'm putting the water based one back on.
Your coolant aims for 90 degrees which is also where you want your oil. As far as I can see there are no drawbacks from having both. The BIG drawback I see from not having the water cooler is the warm up time. It takes a good 10-15 minutes of 50+ mph driving to get mine up to 70-80 degrees oil temperature from cold... and that's with a turbo heating it up! A mates vr only takes 3-4 minutes of the same drive with the same oil to reach decent oil temp.
C2 sell an adaptor to fit both the water cooler and sandwich plate.
